Still playing with notchbacks
Re: Still playing with notchbacks
A small old leather handbag filled with lead shot or even sand is a common bodyworking tool...
Make the sand in the bag fairly tight too. The tightness depends on what you are forming and the strength or softness of the material. Also, the "banging" tool's head shape can make a difference along with the strength used in forming.
Sounds basic... and it is after making learning flubs :wink: :lol: .
vwfye
Post by vwfye »
The baseball worked perfect!
vwfye
Post by vwfye »
Going from hijumper nose cone cover plate to incorporating a mount too.
vwfye
Post by vwfye »
The new piece, after all the cutting, had a slight warp. Today, after breaking all sharp edges and deburring. I spent time at the 10 ton press. Now, the total roll is under 10 thou. I can live with that.
vwfye
Post by vwfye »
Been trying to finish sanding up the engive cover today. Too much dust to work inside, so I worked outside until the rains came. Driver side is dang smooth now. Passenger side will have to wait for now. When done, probably 95% or more of the filler will be sanded off.
vwfye
Post by vwfye »
After a long, long stint with respitory (sp?) Issues, I went out and blew dust off. Then I inspected the panels and found more flaws. Grrrrr... back to block sanding tomorrow.
