www.apfelbeck.nl
- Can Drive Soon
Eddie Brown
- jonas_linder
- Wesayso
Update in place
I has been more than a while so an update has been placed on our Apfelbeck Site. Still no engine, Not even finalised heads but there is some real progress we thought was worth mentioning...
A teaser Picture:
More on the http://www.apfelbeck.nl/ home page.
We hope you'll enjoy seeing this phase and keep faith in us
At least it's a step up from our last update with that big sugarcube (lol)
A teaser Picture:
That so screams "investment casting".
Ideal for low volume, very complex, high precision castings.
Basically you make what you want out of wax or plastic, cover it in a refractory casting plaster, melt out the wax, and pour in the aluminum. Then you break/media blast off the mold. You can hold a small fraction of a thou assuming you design in the aluminum shrinkage as it cools.
Making permanent, long lasting molds for WAX is also a heck of a lot easier than for Aluminum, and can easily be machined by hand if required.
One of those 3D rapid prototyping printer setups could likely lay up solid form finished parts in wax/plastic directly, accurate to a hundred thou or better.
IIRC there is a DIY version designed by some students at MIT or similar... Open source.
Also, IIRC Blender can produce DXFs, or something that translates. (Free 3D software)
MASSIVE TYPE IV
- Cohibra45
Roberto,
I sure would like to see you guys and the other teams:
http://www.rbernauer.de/
http://www.pro-machining.com/
http://www.aircooledtechnology.com/vw.htm
and Martin and Alex at Bugat5speed
get together and form a true international consortium group. All could share information, ideas and most importantly costs/rewards. This should make all concerns time lines much quicker. The different styles of heads, Jakes push rod 'Porkies', apfelbeck single ohc 3 valve, and your dohc 4 valve. I'm sure that each will have different costs/uses and the resulting benefits for all the VW aircooled community will be tremendous.
Just a thought. As Jake said over on his forum, a group working together can accomplish much more faster than individuals. I plan on posting this over on Jakes forum and Shoptalkforums and see what ideas and talk can be generated.
Kelly (Cohibra45)
Kelly (Cohibra45)
L.A.R.D
dont forget www.laperformance.co.uk
just because we dont blurt it all over the net, next year we will release 2 new 2 type4 heads, billit ohv and billit ohc.
- Wally
Re:
Actually, yes there is
Since 2007 lots of things happenend, mostly life
but not so much on the project anymore.
I am a bit tenacious however and the team let me have a go at it to get these realised one way or the other
So it isn't over and I have since made contact with a mold-making company with close relation to a foundry to help out. I also did ask around with the largest and even local 3D printing company's but to print in alu, costs even after 15 years are still very high.
CNC billet has also been a consideration as I have very good experience with a set of those already, but although its less costly, the heritage of these heads are cast. And cooling wise, something can be said for a the raw surface of cast fins I suppose
On the personal side, the modelmaking/casting company guy is really on my page and very close by, so my decision was made to go ahead with the (sand) casting option.
For some reference to nice Autocad pics from an equally old thread (wesyaso kept the website going fortunately):
viewtopic.php?f=1&t=70405&hilit=apfelbeck
Because two of the old (non-usable) castings were made for 98mm and we have these days a great source for biral 98mm cylinders (AA, yes those really are pretty good and very cheap), i got (another) set and made a temp set-up with a 98mm biral cylinder and a set of top-only (the short ones) original type 4 head studs (these heads also feature equal length headstuds):
One of the original castings (yes, its a large head volume!):
Of course I'll keep you guys updated on the progress.
Walter
