What did you do to your turbo today?
turboblue
Re: What did you do to your turbo today?
Post by turboblue »
MarioVelotta wrote:
Is there a purpose for the groove between rings?
It's V shaped and they call an accumulator groove.
Ross puts it in most all pistons.
Don't totally understand what it does but for whatever reason..........its there.......... 8)
Gary
Turbo VW Sand Drag Buggy
2013 Polaris Ranger 4x4
My Website
Shop Facebook Page
Chip Birks
Post by Chip Birks »
I think my wisecos have it too...I think...
juki48
Post by juki48 »
Drove it for the fist time today!!!! :D :D :D I bought ghia 6 years ago with no engine. built an engine over the 6 years (2 kids, new house, yadda yadda) and finally took it down the road. OMG is it fast! only hit 137.5 kpa and it felt sooooo goooood! can't wait till spring when I put some plates on it and can actually leave my street.
Turborob
Post by Turborob »
I'm trying to build a stock 1600 dp turbo . I have a ar/50 turbo and was wondering if the turbo was tooo big? Any info would be good to help me ..... Thank you and have a wonderful day
miniman82
Post by miniman82 »
A/R means nothing without also knowing which series we're talking about. T3? T25? T66?
MarioVelotta
Post by MarioVelotta »
Turborob wrote:I'm trying to build a stock 1600 dp turbo . I have a ar/50 turbo and was wondering if the turbo was tooo big? Any info would be good to help me ..... Thank you and have a wonderful day
Here you go, 42 pages of 1600 turbo
http://www.shoptalkforums.com/viewtopic ... 3&t=127936
The Dub Shop
Mario@thedubshop.net
1600 ITB NA - 18sec
Facebook-Tech-Store
Clonebug
Post by Clonebug »
What is the diameter of the turbine outlet and the compressor inlet???
I have found that an inlet and outlet diameter of 2 inches gives great power after 3500 rpm with the one turbo I used off of a 1987 Subaru and the turbo I used that had a 1 3/4 inch diameter turbine and compressor inlet and outlet came on strong at 3000 rpm.
Whether they are the best I don't know since the inlet air gets pretty hot at 12 lbs boost but for the $25.00 they cost me it works good enough for now.
brookester
Post by brookester »
Almost done converting from a draw through to a blow through.
shag55
Post by shag55 »
Very clean set up! At those Dells or Webers?
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
shag55.sl1racing@gmail.com
Facebook at SL 1 racing
brookester
48 Dells.
E_bug
Post by E_bug »
I grinded smooth the frankenstein welding job i did on my exhaust mani. I have a lot to learn about penetration even though i expecting another baby :shock: .
Tig welding lessons are next in order along with sourcing a used tig.
I also removed the rear motor valance for easy removal of the motor. oMG why havent i done this a long time ago?
My welding sucks .
John_S
Post by John_S »
actually got to drive it , only to my parents for xmas dinner though :)
to the honda civic type r driver i went flying past ........ bet u werent expecting that was u
DerrickfromNC
Post by DerrickfromNC »
brookester wrote:Almost done converting from a draw through to a blow through.
Have you done any mods to your 48 dells to run in the blowthru application? I understand that some get away with just adding modulator rings and emulsion tubes.
brookester
I bought them from someone that was running them on a turbo sand rail. It looks like the mod rings and turbo e-tubes are all that are done to it. I opened up the inlet a little bit and removed the filter but I don't know that it was necessary. It looks like the jetting will be in the ball park already.
E_bug
Post by E_bug »
I leak checked my frankestein exhaust manifold.... OMG. Tiny bubbles all over ..
More welding , welding...
I let it cool of so i could test it tommorow.
Has anybody ever leak tested an exhaust manifold? And what where the resaults?
:shock:
My welding sucks .
