Ricko's New Ride-'71 Baja
Re: Ricko's New Ride-'71 Baja
Mr. Suave, lookin' mighty nice! Funny how a good build is so much improved by the right fenders sitting at the right height. Cruz in fun dood; sit low in the seat, elbow out the window and lookin' gud.
- rickosuave1987
Well I finally got the car (mostly) back together after welding in a new bung for the inner pivot.
Only took me 2 1/2 months...
Baja
HookIt
SuaveRacing FaceBook
HookIt
- Devastator
The helicoil didn't hold?rickosuave1987 wrote:Well I finally got the car (mostly) back together after welding in a new bung for the inner pivot.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- rickosuave1987
Devastator wrote:The helicoil didn't hold?rickosuave1987 wrote:Well I finally got the car (mostly) back together after welding in a new bung for the inner pivot.
Actually it was my safety wire that didn't hold
Turned out not to be too hard to just cut it out with a torch and welding in a frankenstein piece off of a new pivot.
Baja
HookIt
HookIt
- Devastator
That sucks! It also sucks that the Helicoil argument will never be settled now.rickosuave1987 wrote:Actually it was my safety wire that didn't holdThe safety wire broke or came undone (not sure which), and the bolt back out enough to ruin the threads again...
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- rickosuave1987
Yea, sorry I couldn't settle that argument properly.Devastator wrote: That sucks! It also sucks that the Helicoil argument will never be settled now.
The threads were still somewhat intact after the last incident. But the hole had become oblong, so there was no way I could snug the bolt down well.
Baja
HookIt
HookIt
winifredevw
Are you going to safety wire again, or try something else?rickosuave1987 wrote: Actually it was my safety wire that didn't holdThe safety wire broke or came undone (not sure which), and the bolt back out enough to ruin the threads again...
- rickosuave1987
Not entirely sure just yet. The hole in the new pivot bolt will probably accommodate a 1/4" bolt and I could bolt it through the gusset right above. I also picked up some safety wire that says it is good for up to 25 lbs. I am not sure if that is a good number or not though...winifredevw wrote: Are you going to safety wire again, or try something else?
Baja
HookIt
HookIt
- bajaherbie
bolt it.......
winifredevw
I might be a little biased, but I like Skid's fix.
- Devastator
X2.bajaherbie wrote:bolt it.......
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- takotruckin
Damn Rick, you work as fast as I do
- CopperBaja
Rick, in your defense, I don't get in the garage much when it's hot either....August/September are the worst.
96 Pathfinder 4x4 - Family Offroader - 6" "Lift" (2" coil lift + 4" Sub-Frame Drop)
- Devastator
That's for sure!CopperBaja wrote:I don't get in the garage much when it's hot either....August/September are the worst.
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- CopperBaja
Dude...you're in AZ...where I live gets hot...but doesn't compare, I'm sure.Devastator wrote:That's for sure!
