My draw through turbo
advinnie
Re: My draw through turbo
Post by advinnie »
Here's my ticket
V8Nate
Post by V8Nate »
Congrats!
andy198712
Post by andy198712 »
wow that's ace! huge show, i've been a couple times :)
...in reference to a PID control question apparently much earlier in the thread...?
https://www.google.com/url?sa=t&rct=j&q ... qE4Ud1dCUw
advinnie
Post by advinnie »
😭😭😭😭 I'm going to have to turn down the volksworld show I've just been informed that my exhaust manifold will now not be ready in time
advinnie
Post by advinnie »
Piledriver wrote: ↑Thu Feb 28, 2019 9:39 pm ...in reference to a PID control question apparently much earlier in the thread...?
Cheers mate I will have a look at the link in a bit πŸ‘
advinnie
Post by advinnie »
https://youtu.be/OoD_DayC87E
https://youtu.be/c5KM-tpoAzY
At last new manifold fitted with a slightly smaller tube size and the turbo spools so so so much better 😁
advinnie
Post by advinnie »
Now hitting 12 plus psi boost at 2600 rpm 😁
buguy
Post by buguy »
Man that sounds great!
advinnie
Post by advinnie »
It sounds even better in real life 😁
advinnie
Post by advinnie »
Hi all, how's it all going with you lot?
Well I've been busy playing with the bug (Blue Thunder)
But an still fouling the spark plugs very quickly. I've had my A/f ratio equipment checked out and its all working as it should. Anyway I've spent alit of time tuning and here's the figures I've ended up with on cruise but I'm still destroying plugs.
These are crusing figures
Idle-13.7:1
1500 rpm - 12.7:1
2000 rpm 13:1
2200 rpm 13.5:1
2500 rpm 12:1
2600 rpm 11.6:1
2800 rpm 11:1
2900 rpm 11:1
3000 rpm 11:1
3100 rpm 10.9:1
3300 rpm 10.5:1
3500 rpm 10:1
3700 rpm up 9.5:1
Gently acceleration 12:1
Hard acceleration lean spike for a brief second to 16.9:1 then drops to 10:1 ish
Now these figures don't look to bad to me, yes a little rich but nit enough to foul the plugs.
Now I'm guessing the rapid increase in richness at 3100 rpm must be when the mains are coming on cause the A/f ratio stabilizer at 2800 rpm for a little while.
So are my figures still to rich?
Chip Birks
Post by Chip Birks »
That thing is extremely rich everywhere it shouldn't be. 9.5 is as rich as that sensor will measure on the gas scale. So really you have no idea what is happening above 3700. You are cruising at freeway speeds at much richer than you should be seeing at full boost. The tune is WAY off.
advinnie
Post by advinnie »
I do realise it's rich but here's the issue. I can nit drop the idle jets down a size. I'm running 45f8's now and if I drop down to a 40 the engine will not idle due to it running to lean. I've even tried 45f2 which has a bigger air hole but once again she will not run/idle due to being to lean. The smallest idles I can run which will allow the enfine to idle ar 45f8's but as you can see from my figures she runs to rich when on the cruise.
Now I have found a way to lean her out across the board and have much better A/f ratios by going from a pair of 30mm vents to a pair of 32mm vents but the throttle response is crap and the bug becomes all most impossible to drive in town unless you are at full throttle
advinnie
Post by advinnie »
Draw through guys what air fuel ratios are you running and what size jets?
advinnie
Post by advinnie »
My jetting
Weber dcoe 40
Idles 45f8
Mains 150
Pumps. 70
Vents 30
