One of the other weekends I could have worked on the Vanagon I did a few other things worked Friday and then ended up helping Fuser move the Westy Clip from the Pickel.
Couldn't get out of 4th gear on the Massachusetts Turnpike as the drag from the roof was just too much this is with my foot on the floor bearly holding speed thankfully it was late and there wasn't a lot of traffic didnt make it home to bed until 3 AM.
woke up early as I do for work normally my father had picked up a Subaru that had lost a timing belt at speed an interference engine that might have had the valves kiss the pistons so I took a few minutes to pull the heads to have a look see turned out to be pretty bad:
Guess the block, head and rod are toast the crank should be salvageable I do have a block with a set of pistons just need a set of rods and should be able to build an engine.
After loading up some Vanagon parts decided to look into the strange noise the trailer was making to find a toasted wheel bearing time to change it before I headed to the Litchfield Bug in in CT
turned out the other one wasn’t far behind and let go on the way to the show meaning after selling all day and being without much sleep I had to replace it in the field at the end of the show so I could go home
