The "Bring it Back" 71 Super Vert Thread
Re: The "Bring it Back" 71 Super Vert Thread
Marc wrote:I don't see the plastic dammit in the shroud that's supposed to keep the accelerator guide tube in place.
Perfect name for that part, :lol: I needed that, thanks!
mountainkowboy
Post by mountainkowboy »
Spent most of the day yesterday rebuilding the wire harness from the regulator back. Most of the wires in the engine compartment were a little dry and crispy. The rear harness in the sedan was cut for the engine part, so I pulled it out from the regulator back and used the soft supple wires that were in the car to replace the crispy ones on the vert. Solder and shrink tubed everything I did and now the wires in the engine area are like new!
71 Ghia Coupe........For Sale
71 Super-Beetle Convertible.....returning to DD status
63 IH Scout 80 (beater)
mountainkowboy
BAJA-IT wrote:Those pillars look real good. Just let me know what you want for them when it comes time to cut them out.
OK, getting ready to chop the blue one into pieces, let me know what anyone wants off it before it goes to scrap.
BAJA-IT
Post by BAJA-IT »
I'm still interested in the lower a-pillers!
I can send UPS call tag to cover the freight if you can box and weigh them.
BRAT Motorsports #936
mountainkowboy
Got busy and cut the parts bug up today, remember I'm moving and wont have the room for a lot. Saved the parts I needed for the repair of the vert and the rest is in pieces ready to go to scrap.
BAJA-IT
Post by BAJA-IT »
I would still like those A pillars!!!
6" in front of the seam and from the hood opening down to the rocker. The outer 4"-5" of the dash would be a good place to cut too.
Let me know how much $.
Thanx,
Cameron
Need them for the front of this car.
mountainkowboy
So since Vivian is going to be put back on the road this week. I spent the last 3 hours panel beating on the driver rear wing straightening it out and aligning the tears for welding in the morning, the LR fender just didn't line up well. It was just to windy this afternoon to weld on her. Hopefully there wont be any wind in the morning and I can get it done and the fender back on.
mountainkowboy
1 hour and 45 minutes......pulled from the Ghia and stabbed in the vert. Its not hooked up yet, I'll do that in the morning. It's REALLY HOT here and I've done enough sweating for the day.
mountainkowboy
She lives again!!!!
Finished the install on the engine today and went through the front end basic adjustments, remember EVERYTHING is new or redone up there along with the rear suspension. It has a small rake to it, but there is only 2 gallons of gas in it and for some reason I have no brake lights. It's windy as hell here today so I'm done playing outside for today.
mountainkowboy
Ran around town for a bit today, went to the market. It drove pretty good and has good power. On the way home I had a strange rattle sound under acceleration only. Stopped by a friends house and BS'd for a bit, when I started her up there was the rattle. It was coming from the drivers side of the engine, sounded like a loose valve adjustment...then it just went away like it was oil starvation. Will have to pull the valve cover and see what I can see. Maybe a failing lifter? Hasn't ever made this noise before.
mountainkowboy
Got my Topline ball joints in today and will be installing them next week. Shortly after that the engine will be installed and it will be my DD again.
