NQ JQKE
- Hedrock
- david58
Re: NQ JQKE
I made a mount for my GPS using part of the suction cup adapter.
- Leatherneck
Re: NQ JQKE
Where are you putting it?
- bajaherbie
Re: NQ JQKE
i think he is going to clamp it to his wrist...
- david58
Re: NQ JQKE
I didn't get a good pic of the GPS, but I did take some pics. I got the spring plate notched and put back on the car. I am going to let the bearing go for now. Since there is no grease leaking it must be the inner bearing. It is no worse than it was before last weekend. I moved the mirrors up higher also got the flag put on.
- nilza
Re: NQ JQKE
you know david, for a full body baja it sure does make for a mighty fine looking rail.
How are those huge front tyres with the 914 rack and pinion?
- Leatherneck
Re: NQ JQKE
Nice looking rail you have there David. Drive it and enjoy it...
- david58
Re: NQ JQKE
Not sure I had excessive toe out on the rear and had to re-slot the holes on the LR so I could set it. Haven't been off the pavement since putting it back together yesterday evening. Fixing to go to PIG'S EYE MUD BOG and watch the $ wheelers tare up their junk.nilza wrote:you know david, for a full body baja it sure does make for a mighty fine looking rail.
It's growing on me I like it more every time I drive it. Just need to re-think how the windshield isn't streamline as it is slowing the car down in 4th. It was faster with the body on.Leatherneck wrote:Nice looking rail you have there David. Drive it and enjoy it...
Re: NQ JQKE
"... Just need to re-think how the windshield isn't streamline as it is slowing the car down in 4th. It was faster with the body on."
Now that is interesting to read. David, just for the heck of it tape several pieces of cotton on it, top, bottom, sides and in the middle if your windshield; I might even be tempted to put a couple of cotton pieces on the rear hoop and the rear cage over the engine just to see what is happening. Then go for a ride having someone take some video. That would be extremely interesting to see vide of.
- bajaherbie
Re: NQ JQKE
cut off 4" to 6" of the top and cut the bottom foot or two off... just have it cover the a-pillar and not whats above it or below it.
- david58
Re: NQ JQKE
NO.bajaherbie wrote:cut off 4" to 6" of the top and cut the bottom foot or two off... just have it cover the a-pillar and not whats above it or below it.
- bajaherbie
- Leatherneck
Re: NQ JQKE
David a rail isn't streamlined even as much as a Bug, all the tubes and attachments are all creating individual drag which all adds up. Switch your tires back to the smaller ones which will also help.
- david58
Re: NQ JQKE
I drove it with the smaller tires it was still slower with the body off, so that would only be a band aid. There are two things that will make it faster, One would really cost some money.Leatherneck wrote:David a rail isn't streamlined even as much as a Bug, all the tubes and attachments are all creating individual drag which all adds up. Switch your tires back to the smaller ones which will also help.
- Lew
Re: NQ JQKE
David, how bout adding a piece of sheet metal, and trimming down the windshield.
Click on the picture to enlarge. I like this idea!
