anyways lexis dad came down with the key and we cranked it over and he fired right up. shut down, restarted no problem, but hen the battery was completly flat. We jumped it after I fought with the alternator adjusting bolt, finally got it loose, cleaned the threads and put it back together but still 0 charge, somewhere a wire is not connected. Fired it up again, still running lumpy. Got the throttle cable adjusted, but it needs to be replaced because it is too kinked to work. Revs quick and smooth. After some poking around, I have a question sneaks. I know this is a replacement engine, so maybe the firing order is different?
next time I am by I will splice some more wires together so that the reverse lights work, along with the choke. Also the alt warning light si not hooked up. i know on a bug this stops the alt from working, but I don't think this is true on a bay, but I have been wrong once before. Also the oil leak took off like crazy after i swapped the wires, i think the extra crankcase pressure or something did it. so I was gonna go for a test drive but the leak was too much. I hooked the crankcase vent to the air cleaner that you had plugged sneaks, any reason it wasn't hooked up to begin with?
sneaks I apparently have about 4 pms from you, gonna go read those then update this threadd w/ parts needed.
