blow Vs Pull through pros and cons
fuey22
blow thru
Post by fuey22 »
i just finished my engine its a 1699 74x85.5 single weber 44 carb blow thru system and i didnt expect it to run as powerful as it is it makes 10 pounds of boost in 1st gear i have the waste gate set at 13lbs. so far trouble free. if your driven normal in first gear shift to second mash the pedal when boost hits about 10lbs it breaks the tires loose same in 3rd gear its a blast to drive. starts every time no problems so far except for the rubber gasket in the carb have to replace it i dont know if boost killed it or fuel ate it turned to like powder.then started to leak. im totally happy with this setup now im going to build the next motor with a blow thru 4 barrel.
73RAT
Post by 73RAT »
what turbo you are using to make 10 pounds in first
seabeebuggy
Post by seabeebuggy »
That is a lot of boost there. are you dragging a Camel behind you? J/K
www.BigMikesGuns.com oe https://www.BMGAA.com
Thomas Jefferson said It may be necessary for a country to have a revolution every 200 years to right the wrongs of a Government.
Got Lead?
Eddie Brown
Post by Eddie Brown »
73RAT wrote:what turbo you are using to make 10 pounds in first
Schwitzer SA2. (T3 clone).
vwfye
Re: blow thru
Post by vwfye »
fuey22 wrote:i just finished my engine its a 1699 74x85.5 single weber 44 carb blow thru system and i didnt expect it to run as powerful as it is ...
can/would you email me a pic of the set up?
Notchback mid-engine speedster
Little Giant Killer 3
Eddie Brown
Re: blow thru
Check out this post with pictures
http://shoptalkforums.com/viewtopic.php?t=102494
Manuqtix
Re: blow Vs Pull through pros and cons
Post by Manuqtix »
I have a question. Does intake manifolds become restrictions with draw through than with blow through?
Is that part of the pros and cons?
Lo Cash John
Post by Lo Cash John »
A restriction is a restriction. Can you be more specific about what you have or are planning to build?
