Bus beam mounting pattern
- fusername
Re: Bus beam mounting pattern
yeah im talkin to you
The thing was rustier than I remmebered, but you can still get the mounting pattern and all that you needed off it. If you need anything else, let me know.
vegasvolks
Youse freaking tawkin' to me?
I got it (what's left of it) today. Give me a bit and I should be able to get what dimensions I need off of it. Do you want it back when I'm done?
- fusername
yeah i was hoping to remount my beam with it, this lifted one is too much, so i figured I would go back to stock with what I sent you
- fusername
any news on the lift plates? would love to get my hands on a prototype front, I'm all set in the rear (don't say it)
knox
do the later brakes bolt on to a 71, as in the calipers, rotors and such?
are the later brakes bigger/better?
knox
knox
vegasvolks
Patience grasshopper, this is a busy time of year to try to get projects done let alone what I need to get done.
- fusername
well keep us updated, this all is too much fun. Now that I have finally started abusing my bay offroad, I have been bit hard by the bug. Look what I got coming in the mail
deal was too sweet to pass up. Goes in next summer, aught be fun.
- fusername
so did the tetnus shots take? I might actually end up passing on my set of lift plates, but I am curious if you have any drawering to post up just yet? I hate to see the best thread in this forum die out so peacefully.
bajavwbus
http://www.fvwa.sitefactory.fi/data/30.pdf
Here you go fusername. If you want a lift, you just have to adjust the dimensions.
- Daniel G
'71-'72 Front and rear brakes are different than the '73-'79 units. Not so much on the rear but the front stuff is a lot different. The rotors are thinner and the calipers are different as they use a smaller pad. I believe the spindles may be different as well but I can't remember. The rear brakes are an easy swap to the late stuff as I did this myself on my '71 Panel. I just don't remember what I had to change. I know the backing plates but I don't remember what else right now. I have forgotten some of the stuff I used to know about bays..
The front beam patterns are different. The pattern is smaller on splits and bays up to the '69 model year. So you can put an early bay front beam on a split or a split beam on an early bay. From the '70 model year and up the mounting pattern is the same. Here is a thread with a diagram
http://www.thesamba.com/vw/forum/viewtopic.php?t=156615
- fusername
spindles are different, easy to tell apart, M14 caliper bolts for the late style, M12 for the early. backingplate is different, i think only the bearings interchange.
