What year is your 411? from my information...all but probably the very easrliest (68-69) should have had the cross bar at the bell housing/clutch area. See if you notice a pair of vertical holes in the body, outboard of the two top bolts. The bar is actually two piece...with a flat crosss bar that bolts to chassis which th lower bracket bar bolts to.
It sounds like you are doing everything quite correctly. Working on one and driving another.
If I might inquire....what happened to the other transmision? did it get damaged...or just worn out?
The reason I ask is that there are several dangerous wear patterns that the upper crossbar prevents.
The rear side to side adjustment and tilt should still be in the rear handger bar (the two horizontal slotted 8mm bolts at each end and the single vertical bolt at each end)...the the early outer rear hanger bar mounts are probably not the same as later models.
The only reason the top hanger bar exists is to "suspend" the transmission so that the round rubber bumper at the forward end stays centered in its bore...and does not bear against any of the sides.
Thinking that yours will need this also...but that there might not be a top bar on the early model....just reminded me that there are a pair of odd and totally unused holes in the rear beam....one on each side of the transmission. They have slightly slanted/pressed mount areas around them. A simple pair of steel eyes and a transmission strap..or even a cross bar with a rubber bushing could be installed here very quickly to create the same function. Ray
