Hood hinge fix:
Here is a sequence of pics showing the damage to my hood from when it opened up "at speed" and how I fixed it.
This is what I started with:
The force ripped the hinge mount clear off the inside of the hood. As you can see, all these hoods have holding the hinge plate in are two little rivets and a "blob" of resin. Nice. That wimpy little 1/8" steel plate with taped holes is all that the hood has for threads to bolt onto the hinges with. This needed upgrading since they were on the verge of being stripped just from bolting the hood on a few times:
Dressed up the edges of the amputated hinge mount. Beforing cleaning up the edges for repair, I used a sharpie marker to make a bunch of witness marks so I an align the hinge bolt holes close to where they were originally:
I drilled out the stock 1/4" tapped hood holes and welded 8x1.25 nuts to the inside of the original bolt plate. I added a third rivet in addition to the two it had, and for good measure JB welded it as well:
Here the hinge mount has had the backside packed with chopped fiberglass mat and glassed into place using my marks from earlier.
I followed this with sanding, and more fiberglass work. Finally, a touch of filler and some primer. It isn't perfect looking but it is much stronger than the hood was originally. The other side of the hood survived the incident and is still as it came from MARK V fiberglass.
Of course I signed and dated it so I remember to not be stupid and drive without hood latches!
s
