Now the only question is, do I go for the Red9design front end if I'm going to have a rear end to complement it !
The original torsion bar setup has the advantage of having lots of different ARB's available for it so I can tune and change it to my preferences. The fact that the Red9design doesn't have an ARB at all does worry me a bit as it'll be harder to change the settings on the front of the car, Thanks for all the feedback, I had originally been concentrating on the front suspension in isolation and forgot to look at the front & rear as a whole.Marc wrote:Sounds like a good plan. You'll have a choice between the double springplate setup used on early IRS (and all Type III) and the single springplate setup that later Beetles (and the Trekker, I'm told) have.
Your present rear t'bars are 21mm. Beetle/`Ghia IRS are 22mm, Squareback are 23.5mm. Not certain about Fastback & Trekker.
I think you'll be happy with the torsion bar front end. Personally I'd cut & turn it (or install adjusters) for a ~1½" drop, and get the new rear suspension set to match using Squareback t'bars, but it's also not dumb to leave it stock and bolt on low-profile tires for track days - those have the added advantage of lowering the effective gear ratio.
The stock steering box and layout is a compromise, but it works surprisingly well - it's difficult to convert a torsionbar front end to rack & pinion without major bumpsteer headaches, IMO not worth it.
Back in my circletrack days I ran the stock steering and "primitive" suspension, it proved more than adequate against cars with far more sophisticated setups.
What width and tire combination are you considering that'll work with your Ghia?flat_iv wrote: I have been thinking of sending my front wheels to have the width modified.
