Ultimate street car suspension... ?
Re: Ultimate street car suspension... ?
Thank you!
CSP also sells vented replacement discs, as part of a kit and by themselves, these custom units made by Sebro:
http://www.csp-shop.com/cgi-bin/cshop2/ ... fied%20PCD
Sadly CIP1 nor Wolfsburg West (USA CSP Resellers) do not seem to carry these.
Pierside Parts sells the vented "ghia" Kerscher rotors. $150 bucks a pop last time I asked.
Steve
My Baja Build
My Baja Build
vwo60
Good value, I always laugh when I see brakes like the BAD series with the standard calliper and steel rotor, no increase in braking just appearance and all the kits have solid rotors, marketed as a performance brake kit. these are the front set I made for my early beetle, billet hubs, RX 7 four spot callipers and a 300MM vented rotor.
jhoefer
Given your options, I'd personally just run your existing beam width and change to a wheel width and offset that will get flush with the wheel well. Going from your original specs, 6" ET+50, 5.5" ET+45, 5.0" ET+38 would all account for not narrowing the beam 2".Jprather wrote:That doesn't sound too good. I wanted to lower the car with drop spindles so I didn't change the geometry too much.jhoefer wrote:You won't have a negative scrub radius, you'll be making your car's original positive scrub radius larger. The drop spindles increase scrub by moving the tire outward (further away from the balljoint steering axis). Running wheels with a lower ET also moves the tire centerline outward, increasing scrub radius. You are going to feel an increase in steering effort, an increase in kickback from the steering wheel over bumps and under braking. Could make parking lot steering easier however.Jprather wrote:Will I have too much negative scrub?
The fiberglass fenders don't give me to much room to work with, about 2" from the face of the rotor to the edge of the fender.
Any other thoughts on how to make this work? Would a 5" rim improved the situation? Or 7"?
I'm open to any suggestion. I just want a good looking VW that's fun to drive. I have never altered a VW before so this is all new.
Three ways to reduce scrub radius:
1) Larger diameter tires. Aesthetics usually wins out here so probably not an option. Also, diameter increases are large for the amount of scrub reduction you get.
2) Larger ET wheels. Scrub radius is relative to the center of the contact patch, width of the tire won't move this much. Larger ET moves the contact patch closer to the car. As vwo60 mentioned, he went to +50mm to correct his. But offsets that high can be hard to find, but wheel offset is the most common method to alter scrub radius.
3) Widen the front beam (or in your case do NOT narrow the beam). This will push the spindles out and you can run a more standard VW offset wheel that will fill out the wheel well without needing to use the low ET/high width rims.
Otherwise, the scrub radius is determined by the ball joint locations which you can't do anything about without a custom suspension and spindles. Lowering the suspension with an adjustable beam will reduce ride comfort and can affect bump steer. Unfortunately, suspension design is all about acceptable compromises.
Hmmm I might have to make up some hubs for a T3...
One common setup for Porsche racers is to use the surprisingly cheaper late model rotors for the Cayenne over cut down stock hubs. (have cast in hats/one piece vs bolt onto the alloy hub)
- Fiatdude
MENDEOLA has some bitchen brakes -- but I believe you need 17"+ rims to run them
The Mendeola setups I have seen were shown with Airkewld..Fiatdude wrote:MENDEOLA has some bitchen brakes -- but I believe you need 17"+ rims to run them
ET40++ rims are very common on modern vehicles.
Getting them in under 17" is getting more difficult...
Chris V
Finding narrow 17" rims for placement on the front, under a stock fender along with a lowered ride height is challenging. Last I checked a couple OEM Porsche Cayman rims were offered in 17x6.5 ET55.
OEM 944 & 986 based kits are also an option increasing component selection and vendors - http://vdubengineering.com/brake-parts-kits/
Critter1
In my original post I didn't mention.. I'll be running wheels with 4x130 pattern, which makes it all that more difficult to find vented/drilled rotors. I like the Kerscher vented/drilled rotors. On their site they only list the kits. I emailed inquiring if they'll sell the rotors only.
BTW.. I'm liking all the replies in this thread. A lot of the info I was looking for, all in one place!!
Critter1
WOW.. that is one helluva deal. You'd eat up $7k in no time and not be anywhere near where that build is as it sits! Florida.. hmmm.Fiatdude wrote:Critter -- drop what you're doing and race over to the east coast and get this car -- it is a steal
http://www.thesamba.com/vw/classifieds/ ... id=1645751
\Here is the build thread
http://www.shoptalkforums.com/viewtopic ... 1&t=141621
Chris V
These custom hubs will open up a world of options:Critter1 wrote:In my original post I didn't mention.. I'll be running wheels with 4x130 pattern, which makes it all that more difficult to find vented/drilled rotors. I like the Kerscher vented/drilled rotors. On their site they only list the kits. I emailed inquiring if they'll sell the rotors only.
http://vdubengineering.com/products/bra ... llet-hubs/
- Jprather
I am running p205/75/r15 tires. They are just over 26" in diameter. Would that compensate or improve the scrub radius?jhoefer wrote:Given your options, I'd personally just run your existing beam width and change to a wheel width and offset that will get flush with the wheel well. Going from your original specs, 6" ET+50, 5.5" ET+45, 5.0" ET+38 would all account for not narrowing the beam 2".Jprather wrote:That doesn't sound too good. I wanted to lower the car with drop spindles so I didn't change the geometry too much.jhoefer wrote:You won't have a negative scrub radius, you'll be making your car's original positive scrub radius larger. The drop spindles increase scrub by moving the tire outward (further away from the balljoint steering axis). Running wheels with a lower ET also moves the tire centerline outward, increasing scrub radius. You are going to feel an increase in steering effort, an increase in kickback from the steering wheel over bumps and under braking. Could make parking lot steering easier however.Jprather wrote:Will I have too much negative scrub?
I am having a hard time finding finding rims with an ET45 or higher. Maybe I'm not searching correctly.
As a back up, I believe the stock VW chromies have a shallow front space less than 2". I was hoping to do something a little more interesting but ultimately I just want the car to handle.
jhoefer
26" is pretty much the same as stock, so no it wouldn't do much.Jprather wrote:I am running p205/75/r15 tires. They are just over 26" in diameter. Would that compensate or improve the scrub radius?
Yeah, ET45 is about the limit for common aftermarket wheels in the sizes you want. For wheels more commonly found on VWs, the 5.5 ET45 Fuch replicas could be a choice, but you'd still have to change bolt patterns on the drums/discs.
vwo60
If you go to all the trouble of changing the stud pattern then you can use one of the many Porsche wheels that have a ET of 55mm +
coolrydes
Hey guys we have two sizes of front cross-drilled and vented front Cool Stop brake packages with Wilwood 4 piston calipers. They come in 11" for 15" inch wheel guys, and 12.5" for the 17" inch wheel guys. Take a look at them on mendeolasuspension.com
Kevin "Coolrydes" Zagar
MENDEOLA SIGNATURE MOTORS
