MadMike's 'Casper' 76 bug
rs58rag
Re: My latest ride
Sit there idling then just mash gas pedal to floor (dont give it any gas at all before stabbing gas pedal) this is where accelerator pump jets and progression holes work together to accelerate without pre pumping gas pedal. You can check progression circuilt in 5 seconds....unscrew brass cap by a/f mixture screws.
rs58rag
Re: My latest ride
Tried to post pic from phone. .doing something wrong.
rs58rag
Re: My latest ride
Here is 4 progression holes.....was 3. Had to lower camera setting.
madmike
Re: My latest ride
I'll look and see what Idle jets I have in stock,before I start drilling,LOL
Never noticed any issues when stabbing the throttle
but I'll check it out later
Thanks for the tips,, I did see only 3 holes
rs58rag
Re: My latest ride
Madmike said:
I would rather have to fat then lean
, seriously Thinking about swapping the 1915 to 2276
That would be sweet! Your turbo should work great on 2276. By the way nice trade.
madmike
Re: My latest ride
Mater of fact,, that Turbo was on a 2276 when I got it,That and a predator carb
,unfortunately Whoever built it used stock rods
and probably weaken them when balancing them?, or the bolt let go,
, has a hole in the block big as ur fist
(should of used 'Good' H-Beams on a turbo build) didn't hurt the heads or crank
I'm in the middle of the trans build for it now,, searching for a 'Corse' tooth 'splined 0.93 and a IRS good super diff
madmike
Re: My latest ride
Was going with cooling/charging but didn't want a Generator
,then the nice RLR breather was in the way
to relocate the hose were to short
throttle cable issues,,,always something
,I ended up removing all of it
madmike
Re: My latest ride
Gee, the 2276 looks like the 1915
Should get a better pass then 13.2 at 104mph
rs58rag
Re: My latest ride
Did you build the 2276 already? You're fast.....make me feel like a slacker
madmike
Re: My latest ride
I've been collecting parts for this build for over 5years
maybe 1/2fast
hitting swap's,like the Buggy Builder show up here in Lansing and the BugRuns
Has a wedgemated Scat crank & Carillo Rods
044's 42x37.5 ported
W120 Autocraft rockers
madmike
Re: My latest ride
Had a stupid oil leak,, grrrr,, thought it was just a cylinder base leak or the P.R. tube?
Nope, cracked cylinder on #2
with only 10lbs of boost
doubt it was that. probably my old eye's and grabbed the wrong box of cylinders when I built it?changed out the 42x37.5's 044's for the 40x35 semi hemi heads to lower cr. just for shits&giggles,will see how this works ,, but now I can crank up the boost pass 10lbs
Installed a cooling/charging system 'Alt.',,so I can cruise when I plate it
now to relocate the throttle cable(could use one of those little roller tube thingie to go threw the shroud
)quite an angle going up
new lines to the RLR breather(i used a OEM non Doghouse shroud to clear it)I can always add a aux cooler
madmike
Re: My latest ride
Hmmm looking at the pic, seems i can relocate the throttle cable under the turbo?
- rubenski
Re: My latest ride
I used an outer bikcycle-brake cable. The empi woven throttle cable slides right in it. i took the extra long one so room enough to route it.
madmike
Re: My latest ride
Hey Rube,I did use a Motor cycle inner cable and its' plastic coated(outer is Stainless Steel) , but now i'm swapping for a non coated because it's going to get to hot near the header and turbo and I don't need a sticky throttle cable
I'm getting ready to set the timing in this pic,Thanks,madmike
