Link pin to Ball joint conversion questions
- DBUG Nist
Re: Link pin to Ball joint conversion questions
excellent link i like it but ill take a sharpie when i go outside here in a bit and trace all numbers and letters the eye holes for the shocks are the same bottom and top the structure is pretty good it seems ill measure the thickness of the steel on each end and i will also measure the traveling as well thanks again for the info
11' Sentra
Subaru powered railbuggy
DAS SUBARU
DAS SUBARU
- DBUG Nist
the full extension of the shock is 24 inches (2 feet) i wasn't able to get the full compressed and measure it by myself an educated guess might be 15~16 inches?? the numbers on the shock i got F75A-18080-NC / CF11P1A Motorcraft. For some odd reason my ignition fuse blows when i turn the key off?? it doesnt do it when i start it only when i turn it off which is odd to me any ideas would be wonderful
11' Sentra
DAS SUBARU
DAS SUBARU
Are you sure about the number. I can't get it to come up.
- DBUG Nist
positive ill double check the other when i get home but thats why i was so confused i figured the number plus motorcraft it would pop right up.. but i figured it was ford.
11' Sentra
DAS SUBARU
DAS SUBARU
