Custom hide away header
- sideshow
Re: Custom hide away header
Not a chance, even not made by lowest bidder it is too wide and too far back (clears blower shroud).
- buguy
Yeah I went out and looked at my bug and saw there was no way.
DerrickfromNC
Here is an exhaust system that could easily be modified into a turbo header:
http://www.mofoco.com/item/EMPI_3300_EC ... M/3153/c55
- buguy
I was looking at those. I guess if you can cut the glass pack apart and taper it to a flange size it might work. Most guys want to place the turbo where all the tubes are wadded up there.
- sideshow
That econo header design has been offered since the 36hp days, it is an unequal length design with the muffler of near 3" od. The only one I have used a long tapper cone reducer to make it 2.5" 3-bolt domestic flange and fed it into common v-8 mufflers, it was nice to use easy to source parts and doesn't hang down (departure angle) like most.
semipixel
I chopped up an old 1 3/8 header to make this which seems to be similar to what you're trying to do:
kaferboy1
What header brand/model was this that you started from? I am needing to modify an exhaust to work with a 36hp turbo build and have been looking for something to start from.
Sent from my SM-N910V using Tapatalksemipixel wrote:I chopped up an old 1 3/8 header to make this which seems to be similar to what you're trying to do:
semipixel
I used one of these as my start: http://www2.cip1.com/ProductDetails.asp ... e=C13-3100
And I bought v-band flanges to go from it to the j-tubes, but that's personal preference.
kaferboy1 wrote: βWed May 09, 2018 4:09 am What header brand/model was this that you started from? I am needing to modify an exhaust to work with a 36hp turbo build and have been looking for something to start from.Sent from my SM-N910V using Tapatalksemipixel wrote:I chopped up an old 1 3/8 header to make this which seems to be similar to what you're trying to do:
- Chip Birks
I have a ton of vband parts just sitting around waiting for a new header to be built. Might cut the flanges off my A1 header and swap to the bands. So much nicer to work with.
