66 Turbo update.....walk around
- sideshow
Re: 66 Turbo update.....walk around
Neat build, did you bush the bores for the fantastic plastic lifters and what kind kind of pistons/rings do those barrels require?
- Amurray
Not sure what you mean by Plastic lifters?....You lost me. The case is aluminum not magnesium. The entire pistons(JE), rings and head studs was purchased as a kit from LN Engineering.
- sideshow
They are called ceramic but it is sort of a plastic, spooky space aged stuff I also run them in a bare sand cast case.
- buguy
What heads are you running on this set up?
- Amurray
gbaker770
Super nice car and build. I’m in st augustine, there are a few of us up here and quite a few in the Orlando area as well.
Hope you can make some of the stuff going on later this month. We will be coming down for the Turkey Rod Run later in the month for the Bellaire Plaza cruise/hangout on Saturday the 24th in Ormond Beach.
- buguy
Wow I didn't know there was anyone around here!
- buguy
- Amurray
Well the heads does not get that hot to me as I have taken proper precautions. The heads have a heat dispersant on the outside and ceramic-coated chambers. I also run LN Engineering cylinders. The heads sees 250 degrees at idle. The most I have ever seen my heads get was near 350 degrees long durations on the dyno while being push real hard. I don't ever see myself pushing it that hard on the street without going to jail. I also run water injection at high boost and I have a dual set-trab oil cooler. I have never seen my oil temperature beyond 225F and that was on the dyno.
Sent from my ONEPLUS A3000 using Tapatalk
- buguy
Yeah I guess I read they run hotter than others, but they also are strong enough to take the heat. I'm sure most don't go to the lengths you do to keep things cool.
dragvw2180
I would keep my eyes one your valve guides for movement after driving on the street with those heads. I have considered using the coatings on my heads also but decided against them because I have taken my 66 street bug off the road and decided to go back racing again. I hope we meet sometime at one of the races , 2 black 66 turbo bugs . I just built a new GTX3576R turbo for mine also . Mike McCarthy
- Amurray
Mike you live in Floridadragvw2180 wrote: ↑Mon Nov 12, 2018 3:53 pm I would keep my eyes one your valve guides for movement after driving on the street with those heads. I have considered using the coatings on my heads also but decided against them because I have taken my 66 street bug off the road and decided to go back racing again. I hope we meet sometime at one of the races , 2 black 66 turbo bugs . I just built a new GTX3576R turbo for mine also . Mike McCarthy
dragvw2180
Sorry , I live in North Carolina . I will be at Drag Nite next summer but that is about the farthest south my race Partner John Toomey and I will be taking our cars . Anytime you need to talk just PM me your email and I will send my phone number . Mike McCarthy
- Amurray
Will do. Just wanted to chat about the Rev6 clutch. I think I read somewhere the you use them. I'll sent you my information. Thanks.dragvw2180 wrote:Sorry , I live in North Carolina . I will be at Drag Nite next summer but that is about the farthest south my race Partner John Toomey and I will be taking our cars . Anytime you need to talk just PM me your email and I will send my phone number . Mike McCarthy
dragvw2180
Yes my partner John and I both do , would never use anything else after how well it has worked for us. To put it in perspective , before the Rev 6 I did some form of damage to my transmission every race. Since putting the REV6 in neither myself nor John have had any transmission failures. My 60 ft times are in the 1.30 - 1.40s and I never do a burnout, just stage and launch. It definitely was THE best investment I ever put in my car. Mike
