well, I guess last question. I plan on replacing the bushings in the rear this weekend. Should I just throw the 23.5s right in there, or try stock first?H2OSB wrote: ↑Fri Jun 07, 2019 3:25 pm Re 23.5 bars. Absolutely! The car rides very nicely. When I killed the turbo in my Subaru, I had to daily the Beetle for about 2 months. Never felt like it was too stiff.
I'm actually going with 26mm bars in my other Super. I'm going higher spring rate, smaller sways(19mm stock front with urethane bushings, 15mm 944 rear bar). 150# springs onthe front.
H2OSB
How much tire is too much tire?
eskamobob1
Re: How much tire is too much tire?
H2OSB
Don't bother with stock if you're planning to autocross
eskamobob1
No plans for autocross, but I do drive kind of hard from time to time
H2OSB
If you have access to 23.5s I suggest using them. I don't find the suspension overly stiff at all. Firmer, certainly, but not punishing.
H2OSB
H2OSB
