Another blow thru 1600 build
John S.
Re: Another blow thru 1600 build
Post by John S. »
If I choose the Saab bypass valve. I have a few V8 type valve cover breather filters laying around.
John S.
Post by John S. »
Is a 2” pipe ok, from the collector up to the turbo?
Clonebug
Post by Clonebug »
Yes
John S.
Post by John S. »
Where’s the best place to get V-band parts for 2”?
And do I need a restrictor on the oil feed?
buguy
Post by buguy »
Amazon has pretty good prices in Vbands.
And what size is your oil feed line?
Clonebug
Post by Clonebug »
I've kind of switched to Summit Racing for a lot of my non VW stuff due to the really reasonable shipping rates they have.
CB Performance is just killer on shipping and there are others that are really pricey too.
I shipped a set of tires and a couple 2.5 inch tubing bends along with some Brad Penn oil all for $9.99 shipping.
CBP wanted almost double that just to ship the oil!!!!!
You kind of need to shop around......I have an extensive bookmark section of lots of my fav places.......I always check shipping before hitting the buy button.
John S.
Post by John S. »
Thanks for the info.
I have nothing, yet for my oil feed. Would love to find something pre made with fittings.
buguy
Post by buguy »
I found mine at a local speed shop. All set up with the banjo fitting and everything!
John S.
Post by John S. »
I see summit has -4 AN hose for oil pressure gauges. Would that work?
And what’s a local speed shop? Lol
John S.
Post by John S. »
Looks like my turbo is .42 air and .48 exhaust. If that makes any sense.
buguy
Post by buguy »
Yep. That's a pretty common size little turbo. Probably from a Volvo or Saab. I had one of those on my car when I first built it. It was OK. I have a small turbo from a WRX that I like better. But the little T3 didn't work terrible.
Here you can see the oil feed on the top of it. That was a -4 line. I think a -3 would have been even better, but my drain wasn't right at that time so I saw a bit of smoke
https://youtu.be/iZGuFvntQl4
John S.
Post by John S. »
The turbo is off an ‘82 Saab. Is it a T3? The flange really doesn’t match any online dimensions that I have found. T2,T25...?
buguy
Post by buguy »
It's probably T3 flanges. I think they are actually called something like a TB03 or something like that if I remember right.
John S.
Post by John S. »
I think TBO3 is right
John S.
Post by John S. »
On my way to San Diego, anyone local?
