After a few runs 'round the block' here's a small clip of a third gear and second gear WOT pull taken from my dash cam. Its my way of bedding in new piston rings
All on closed off private roads of course
I don't use Edis coils. They are Zetec Ford style (from Mallory), but the drivers are within the ecuMegaRookie wrote: ↑Fri May 01, 2020 10:45 am
If you want to know if your ignition/ecu is the problem you could try running on 1 edis coil. Or switch to sequential ignition or work with an extra ignition driver, but I dont know how that would work on an edis coil?
Mark
After 3 years I needed to open the engine (see story at the forced induction forum) and besides the beautifull looking biral cylinders (also from Pieper), I took the opportunity to machine the steps away that were in the heads before. I also cc'd the heads and pistons properly and I only had 1;8,2 CR before!
I think they still are. Not sure what I did to mine though or what exactly cause my troubles. Always be carefull to stick a general 'conclusion' on something from just one example where no one (not even me, even though they were on my engine) know everything that happenend. Its easy to draw conclusions, but very tricky as well..
