Forged Piston Advice
Chip Birks
Re: Forged Piston Advice
Post by Chip Birks »
What you guys are forgetting is that I was running almost 25psi on pump gas. Straight up Chevron 91 octane. No methanol, no ethanol, nada. Try that with flat tops. That said, I would still go 92 for the thick walls, not because of warping, but strength. You tend to find limits when you lean on them. If timing wasn't perfect, my setup would torch cylinders. I think I've gone through half a dozen or so cylinders in the years I've been running them, dyno time would be a very wise investment here.
All that said, I'm switching to flat tops for my current refresh, hoping to get rid of some engine noise that I think is related to my set of squishies. I'll just keep it on e85 and let it rip. If you have easy access to e85 I personally wouldn't waste the $$$ on squishies. If pump gas is all you have access to, they are probably a worthwhile investment.
kangaboy
Post by kangaboy »
buguy wrote: Thu Sep 24, 2020 2:32 pm Yeah put a better clutch in it!! Then you can get to buy a new trans like me!
I have recently come to grips with the fact that "It never ends" :lol:
Chip Birks wrote: Thu Sep 24, 2020 3:23 pm If you have easy access to e85 I personally wouldn't waste the $$$ on squishies. If pump gas is all you have access to, they are probably a worthwhile investment.
And the internal debate continues...do I want to rely on E85 staying available in my area? Or do I go with a safety net and use the squishies, always knowing I can fill up with pump gas? Decisions, decisions...
'74 Standard- 2084T, MS3X3
'76 Westy- Stock 2.0L L-Jet
My Megasquirt Turbo Build
2084 Turbo Build
Chip Birks
Are you setup for water/meth already? That's half the reason I made the change. My water meth has been in my car since day one, yet I think I've had it active for maybe half an hour of drive time. I just never needed it. I plan to let it do its thing in the future.
kangaboy
Post by kangaboy »
Chip Birks wrote: Fri Sep 25, 2020 8:09 am Are you setup for water/meth already?
I have a kit sitting on my workbench, so while it's not installed and running, it's available for use.
2084 Turbo Build
Chip Birks
kangaboy wrote: Fri Sep 25, 2020 8:21 am
Just another thing to consider. You've already spend the cash on anti detonation hardware.
WickedWagens
Post by WickedWagens »
Im running the AA forged 94mm P&C in my Bonneville land speed car. I had them honed for .0057 clearance and set the rings at .022 &.024. I’ve run 22 lbs of boost for 3 full miles wide open throttle. They seem like a good piston to me.
1968 Karmann Ghia land speed
G/CFALT 106.643 MPH G/CGALT 113.131 MPH
G/CBGALT 169.462 MPH G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH H/CBGC 94.334 MPH
H/CPRO 93.383 MPH H/CBFALT 101.282 MPH
H/CBGALT 120.591 MPH
Top Speed 174.2 MPH
bug66
Post by bug66 »
You don't need TW 92s for just 20 psi :)
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
WickedWagens
bug66 wrote: Fri Oct 09, 2020 1:31 am You don't need TW 92s for just 20 psi :)
You might if your tune gets off a little bit. Thicker cylinders are more forgiving to an extent.
Top Speed 174.2 MPH
