Much thanks C. Appreciate you sharing the wisdom..
Ran out there and ripped it open today.
VERY happy to see no nicks or dings on the compressor turbine!
Valve head came clear off and no visible damage!
Hot side:
2.92" -maybe a bit more- or about 74mm.
It's 2.92 inches because all bolts are inches on this thing.
Forgot i even had inch wrenches..!
Forgot to get the small measurement.
Cold side:
2.76" or 70mm large.
Somewhere around 1.93" or 49mm small.
The shaft spins really tidy and smooth.
There is no measurable end play, but, disassembled, there is about .025" side-play measured from the end.
Does this measurement mean anything?
I'm guessing there's a plain bearing (babbit bushing) in there.
Dag, I'm kicking myself for not getting that other measurement.
Because i have so little storage space i put it all back together..!
Also found some small sticks/leaves/grass in both sides.
Like it sat outside or under a lawn mower or..?
So,
What you think?
How will this thing feed my 2275 here?
Just handling this huge thing I'm starting to get really really stoked!
