Update!
For the first time since my son was born in September, I was able to spend two full days in the garage. Don't get me wrong, I love being a dad but it felt good to get out there and really make some progress.
I got everything cleaned up, ball-honed the cylinders, installed my new copper head gaskets and 8mm chromoly head studs and the engine is now sealed up from valve cover to valve cover. I also have an in-line oil thermostat to install before my secondary cooler so my temps will come up faster. I think I might need to make a bracket for it though...
I pulled the trigger on the AEM WMI kit. By the way, have you guys ordered from Summit racing lately? I placed the order for that kit at like 9am Thursday and it was on my doorstep by 1pm, Friday! So, anyway, I found a few minutes to mount the controller and started thinking about placement for the tank. I don't love the location in the photos but I don't really like anything better. I really wish I could convert the rear window to some kind of hatchback setup. That would allow me to mount the tank on the rear firewall while still making it easy to top off the tank and would open up my options for rear cargo as well...
As for my low boost problem, my plan is to put my intake and exhaust tracts back together carefully while looking for potential leaks. Once I get the car back up and running, I'll try to narrow down my issue by looking for leaks. My main theory is still that my compressor wheel is too small for the recess in the base plate. So I ordered a fresh, properly-sized compressor wheel for cheap off of eBay. After I rule out all other potential leaks or efficiency losses, I'll throw that wheel on the turbo, mate it with the appropriate compressor housing and see if it makes a difference. If it doesn't make a difference or if the turbo eats itself from a lack of balance, I'll have to go back to turbo shopping.
