Nice looking Motor!!!You might have to mount the carb a different way, fuel may slosh away from the jets, but try it u maybe ok, I got a cable from the 'Chassie Shop' up here in Mears Mi, it's called a 'Silver jacket' and is as smooth as butter a lil pricey but I figure it's worth it not to have a sticky throttle
U may need to loose the fancy coil mount ,so you can make the 'T' intake make sure u weld some bungs on it for Gauges and wastgate stuff,,then U can pickup a fuelpump blockoff drain for the turbo ,JayCee is nice,bigger the better,,I was hoping to find a better photo for ya,I have my water/Meth injection line tapped into the intake(red hose) Cheers,Mike
