Making a Straight Axle Kit
alask
I would like to take the credit fore it but i cant!
i didnt make i a frend of mine did!
And yes there are long vinters!
but that gives us good time to make all the mods wee vant fore the next season!
You guys have to hurry so its finishen the next week but whe have at least five moths to do it!
- Eaallred
I just realized last night, that the end castings are also where the swingplate attatches, hence the need for that end casting to be used on the end of the long axle.
I feel stoopid for not catching that sooner.
lol
Eric Allred
64 Bus
64 Bug
lol
Eric Allred
64 Bus
64 Bug
vwdoublecab1966
I have the templates. Will work on getting them on the computer this weekend. Does any one know how the emergency brake cables need to be extended and by how far? What kind of shocks would you run? I noticed that they offer shocks with their kit that are modified.
ntchbak
Hey Doublecab, Glad to see the templates got there. Hope they will work for you. I'll ask my brother to measure the e-brake extentions he got with the IRS Wolfgang kit and get back to you. Sorry the templates were cardboard but that was cheaper than metal ones. Hope you can post then for everyone (sorry Bus Boys and Wolf Gang) You can't keep it all from the eager.
vwdoublecab1966
Emergency Brake Cable Extenders
Does anyone have one information on how to make the extenders for the emergency brake cable extenders. I have been gathering information to post on a website for everyone and that is about the last of what I need to get it all put together...
Jeremy
Jeremy
- DudeAndHisBus
http://www.aussieveedubbers.com/forum/v ... &aid=11375
That site has a great walkthrough on the whole process.
- Bobby74
That site is great!!! The thing that dauned on me though.... Why couldn't you use the long axles inside of 4 standard bug tube cut and mated together? That way you can save the long axle tubes and use the more common early bug axle tubes.
Better yet: Could you buy Long SAW axles and run those inside of 4 cut and welded BUG axle tubes?
Are the T2, Bus, spring plates longer or angled? Why couldn't you just use the beetle spring plate on the Bus chassis?
Can you run standard length BUG axles and tubes to "tuck" the wheels under the bus farther????
I really want to lower my bus 3" and tuck the wheels a little so I can run Cookie Cutter wheels (already have them). The offset is not enough..
Thank you!
-Bobby
Thank you!
-Bobby
- Tony Z
Re:
DudeAndHisBus wrote:http://www.aussieveedubbers.com/forum/v ... &aid=11375
that link is dead.... any chance of a repost?
Flagbuggy
Re: Making a Straight Axle Kit
Hy ZZZZZ Was just sending you a skype message waiting for this one to open and also found out this link is dead
ANy one on that Aussie site that has a new link for us
damo99
hers alink to making a straight axle kit on vzi forum
very easy to follow
http://www.volkszone.co.uk/VZi/showthread.php?p=7531961
very easy to follow
Flagbuggy
HI Thanks
Checked it out but still a question or 2 but will register there and and see If I can ask them
damo99
there is also this one
http://www.kustomcoachwerks.com/forums/ ... aight+axle
i have found 1 more on the how to but i can't remember where it was .
i'll post it as soon as i find it again
Flagbuggy
Thanks damo99
I have got a back piece of a split bus that I am using to jig up
My biggest Question is that the std Spring plate of the split bus when used with the lengthened axle tube
It actually has to be moved +-3 splines on the outer side upwards but then it catches on the top stopper ?? what do the guys do there
Flagbuggy
HI Guys I need some help here
Dont Laugh
The "Spring Plates" are they made of Spring steel
If so and which I think it is how come the guys making the kits weld on to the spring steel ?
Is this not Dangerous
Can the new arms I am planning to make be made out of thickker Stainless steel or what material can I use
Or is there a special Welding prosses that has to be used to weld on the Spring steel
These are the arms that I want to make from skratch and want to make them Adjustable but there is welding involve how does it get done
Pls Help
Dont Laugh
Pls Help
Flagbuggy
Another pic of how the plate will look
How di I attach the Splined part to the plate ?
