NEED HELP CAR WON'T IDLE!!
Re: NEED HELP CAR WON'T IDLE!!
my car is doing the same however the first thing i checked was the valve spring and turned out i needed to replace one of them because it broke after that it ran better but still wouldnt idle for me.?
One trick I use to clear a carb, is to take the air cleaner off, start the engine, rev the engine up as you place your hand over the opening to the carb, and remove it. Do this several times. If there is small amount of trash the vacuum from the motor this will occasionally pull it through. If there are other issues with the carb, this probably will not help.
Mitchell
Mitchell
Mitchell
Mitchell
