Type 5 is good BUT.......MAIN BEARINGS?????????
pocketrocket
pillow thats for T-1 to T-4 adapter brg. If you want 1.9 or 2.1 brgs email me for prices rocky@rockyjennings.com Thanks Rocky
MASSIVE TYPE IV
I have an outlet that can make any bearing you need, they have made 1.9 and 2.1 WBX already.
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
Jake Raby
pocketrocket
I have a supply of 1.9 & 2.1 water boxer kolbenschmidt german brgs. Email me rjenning@hscis.net Thanks Rocky
Pillow
Got some 2.1 std/std/std bearings from Rocky yesterday, very nice guy and we BSed motors for while which was cool as well.
Adrian Pillow
'66 VW Westfalia
'79 Porsche 911 SC - FS
VolkSport Kafer Gruppe
Adrian Pillow
'66 VW Westfalia
alan harland
Just have Rimco make you bearings. Did it for me.
pocketrocket
Alan, What brgs did rimco make for you as new german h2o 1.9 & 2.1 brgs have been available for about 5 months. I bought about 60 sets last yr.(sept 02). Anyone needing 1.9 or 2.1 boxer main brgs. E-mail me. rjenning@hscis.net Thanks Rocky
fastoldvw
Re: Type 5 is good BUT.......MAIN BEARINGS?????????
Old thread, i know, but..
I want to buy bearings for my 2276 oxy build, but i don't know the year of my block.. The dealer wants to know if it is a 82-85 or a 86-90 motor i have.
Can someone explain the difference between early/late bearings, please.
The block and bearings are at the machineshop, so i don't have them handy. The block nr is: 025 101 102
Thanks, Rune..
Thanks, Rune..
- sideshow
Look to see if the #2 main expects a dowel pin or a rod bearing'ish notch.
- fastback
most likely a old style bearing case u have.
the later with 3 piece thrust bearing has a "B" after the partnumber.
Passatman
What's the issue here do the t5 engines suffer the same faith as it's air cooled siblings ( lack of bearings ). I really need some bearings for my 2.1ltr t5 but have to pull the engine to check first.
fastoldvw
I think the problem can be to get bearings for align bored cases.
Mine are std in case and .010 in crank and are available at least with CSP both in germany and sweden..
However, these blocks rarely need align boring..
3literboy
I am using Chrysler bearings for #2 and #3 and a Type 4 on #1 and #4.
I found a machine washer for $4.12 that fits the Chrysler O/D perfectly. I am just cutting them in half and making my own center thrust conversion shim. The only mods are a 2.5194 linebore, and a .023 thrust cut and approxiamtely a .045 thrust cut on the center main. The shim will support the full shoulder of a chrysler thrust bearing. These Clevite bearings are superior to anything out there for only $35 bucks. All one then has to do is get a #1 and #4 type 4 bearing....
The shim will drop in, but I will screw it to the journal with nice countersunck screws too.
So, the metal backed clevite thrust bearing will be backed up by a very sturdy steel shim that is wider then the Thrust shoulder.
I believe this setup preserves oil pressure better than a narrowed BMW bearing. In addition, the #1 main bearing shells will be a full sized type 4 also. With appropriate crush, the number 1 metal backed bearings should be very very sturdy....
farmer
That´s with a stock type crank mate
I also suspect something else to be a problem. While the center thrust is very good and nescessary on high power engines, the old style flange bearing trust will handle waay more than 250 hp. Somethings not right.
T
T
