lowering 412S variant
kenneth
Post by kenneth »
i get a bit confused reading technik english :?
if i get it correct
I have to lenghten the catridge housing becaurse the new catridge is longer in the button end (opposite of the strut) than the original was, is that correct
Sorry...got too carried away with language. Actually, the audi strut cartridges have a shorter cartridge and a shorter rod length when extended.
In order for the rod length to reach the right place, the strut body or tube...will have to be lengthened at the top, where the cap screws on. It allows the cartridge to sit up higher so the end of the rod reaches the previous height of the original strut rod.
Since the catridge is shorter....there will be a gap between the bottom of the audi strut cartridge...and the bottm of the inside of the strut tube. You will need a spacer of a piece of pipe inside...to make sure all is steady.
Now...to lower a vehicle like this....you could simply leave the top of the tube alone....and move the bottom bowl...as you call it..downward...whatever amount you want to lower up to 2". I have been neglecting to get drawings of this out onto the web. I will see what I can do in th next two weeks. Ray
kenneth
Post by kenneth »
thanks a lot Ray
it is of incredible value when pepole like your self, use thier free time to help others with the same desire in old care as you self have
thanks a lot and keep up the wonderfull good work :wink:
if you ever need helt with the golf mark 2 let me know that is my speciality, i have 3 right now
1. diesel alomst standart
2. golf2 with golf3 2,8 VR6 engine
3. 1,8 GTI 16v bought it last wensday it is alomst in mint condition, from the south of Germany
Thank you for the offer :) Bear with me on the tech drawings. Ray
kenneth
Post by kenneth »
Hi
I will, theres no rush, as i have writteh berfore, there is no time limit on my project.
It doesent matter if it takes 6 or 12 month
kenneth
Post by kenneth »
:shock: ...... :shock: ..... :shock: Very nice. I have only one question. Are they calibrated to the same stock specds that Boge, Sachs and KYB were? Or are they uprated like most other Koni products. If the yare not uprated...then ...yes they would help most people just going back to original....but what I have installed is at least 100% better thanstock...for less than Koni. But...they make damn nice equip,emt. If they are uprated...thats a steal. Ray
keneth
Post by keneth »
hi Ray
i havent been here for a long time and i didnt come any further with my car.
how is your progress on the 412 lowering, last i heard you were about to make some drawings for the lowering mod
best regards
kenneth
Denmark
Sorry...its been very busy. I will see if I can get the last measurements for the sketches next week. Ray
kenneth
Post by kenneth »
NP Ray
I know the feeling, lots of things to do but, so little time :?
as i havw sayed before im not in that much of a
rush
