Ok, I will expand on my avatar a bit.
I made a "spacer" out of a ball joint front beam that I cut down to 24" wide. I used 1.75" tubing roughly 5" long that comes down to a 6" wider warrior beam.
I then ran bent tubes up to my rollcage, with cross bracing to mount a spun alum tank. This is also plated. I then made new braces between the beam and pan similar to stock using a 20 ton press and 1.5" tubing. The coilovers are 10" Fox reservoirs with 200/400 coils. They mount to L shaped adjustable brackets I got from a friend that normally mount koni coilovers on the rear of drag cars. This allowed me to tune up vs down travel. I've got the cheapo 2.5" longer 1" wider front trailing arms, and 3" lift spindles, turned by a HD rack and pinion and heimed tie rods. I now have a Bilstein steering stabilizer slowing it down. Right now it makes 9" up travel and 5" down travel for a total of 14" All the way up, the pan is 4" from the ground.
3" body lift makes room for the tires in the post, or 31" swampers, which I would like to replace with BFG baja TA's.
3x3 chromoly arms in the back mounting dual 12" fox reservoir shocks off the cage. Still kept the torsions because I couldn't afford to coil the back yet, and it works good. Bypass shocks are in the works, but it's a good 12" of travel in the back right now.
I want to go with combo spindles and 4" longer front arms when I get the funds, but UCLA takes most of what I make. It works really well at Pismo, and I'm hoping to go to Glamis over Thanksgiving.
http://www.thesamba.com/vw/forum/album_ ... c_id=91797
A side shot showing basic idea.
http://www.thesamba.com/vw/forum/album_ ... c_id=91796
Unfinished work showing front suspension.
http://www.thesamba.com/vw/forum/album_ ... c_id=91795
Front truck showing tube work body lift and coilover mounts.
Sorry to make you check thesamba, I dont have any other way, think my pics are too big for here.
It's not Baja Shop, but it works well, and will be a nice car built on a college kid budget. I plan for dual buckets in the back as well, and a maroon paint job similar to the new H2 (bleh)
Hope that gives you an idea.
Jordan
