Cranky cranking...what would you put your money on?
Gigafex
Re: Cranky cranking...what would you put your money on?
did you guys find anything out I am having the same issue with a bug not turning over
- FJCamper
Hi Batan,
If you have a good starter bushing, check the transmission ground strap. A bad ground there causes all kinds of odd problems, including "no start hot" once the strap connection gets even more loose when warm.
The quick check is to run a test ground wire between the battery negative and the engine.
