I know it's rare, but...
- DeathBus
you can just drop the exhaust and heater boxes. Pull the shroad and you have acccess to the cooler. I have never really seen cooler seals go bad, usually just the nuts come untorqued, use permatex on the seals when you put them on, you shouldnt have any problems. Now your cooler might have a hole in it. or oil coming from in between your cylinder and head (I have seen that also), or leaky pushrod tube.
Uber....you know, this is an ugly thought...but if the other gold one had "C" pillar disease.....perhaps that would be an interesting candidate for a simple roll cage system and a couple braces.....and cutting the roof off at the rear window....and adding a rabbit convertible top. I can measure mine and see ...but it should be pretty close. Cooool.! That case...C pillar and roof rot...is the only time I would suggest this. Ray
- ubercrap
You know, I had this thought. I wasn't sure if I should bring it up though, didn't know how you'd feel about it.
When I can get my procrastinating butt in gear and go get it, I'll post some pics of the rust. I got the hitch mostly installed on the new towbeast Crown Vic., but then I was driving around the other day and it started to overheat, I think the waterpump is bad (hopefully I didn't blow up the motor) It's at a good mechanic that just happened to be near where it broke down. I've got some air shocks for that bad boy too-should pull a trailer decently. As soon as I get it back up and going, I'll go get the the rusty gold one and the other from Alabama.
raygreenwood wrote:Uber....you know, this is an ugly thought...but if the other gold one had "C" pillar disease.....perhaps that would be an interesting candidate for a simple roll cage system and a couple braces.....and cutting the roof off at the rear window....and adding a rabbit convertible top. I can measure mine and see ...but it should be pretty close. Cooool.! That case...C pillar and roof rot...is the only time I would suggest this. Ray
Exactly what I was thinking...since I used to own a 900. Only reason I didn't suggest it right off..is that they are a bit more complex. But..I know where about 15 of them sit with tops whose hardware is complete...unrusted and unbent. I just installed a new top and headliner on my rabbit. A company called tops online...gave superb service. It was a factory repro top...exact vinyl, lining, stictching, perfect cut, all heat embossing and heat sealing. It fit like factory. The headliner was about $85...the top was about $165 or so. With overnight shipping...it came to about $325. Can't say enough about them.
Also...i had thought about using one of those long rag top kits for a type 3. You know...about 4' long.....low profile. That would be interesting and would only require a ring of say...2" pipe to be elded to the roof on the inside under the headliner for bracing. So if the C pillar is dent enough to de-rust and spotweld...but the top is trashed....cut most of it out and put in a rag top the size of a bus. Ray
albert
no huber i am not sellers but i know the just price for a good thing , wend i take possestion of my thierd (3) 412 , last year , i buy the car at one condition , the guy geve me a second 412 (same year ) for to make me spare parts (one on the road and one donor ) ok the donor is only for sécuritys for me , ok some parts are very old and use , but for spare??? here in québec (est of canada ) during the winther ,the snow and the salt and the cold are very hard for the car ,5o% of the car receve,évery years e rust proof protection wich oil , my 412 receve that from 1973 ,and all the onder the car parts are 100%rust proof samething brand new , if you need good parts for your 412 look in usa or west-cote of canada , the winther is smooth , and the rust is not so bad , and here for the 412 body parts it is finish , we are only 4 guy approx. witch 412 for the motor parts not bad he have manys type 2 or bus or campers and ruffly it is same parts if you need good parts i have adress in usa witch millions of 412 parts use but good and the price is correct 50.--60.$ for fenders or 100$for door complet i send adress at ray , or if you need that i can send you the page by private adress salutation and good luck
