bought some new headlights for the pickup
head lamps
oh, ray i know, but the low and hi beam relay have fix (stop) on or off , wend you year the click for hi beam the relay close 1 section for low beam and geve power at the second section low beam and same time geve power at the hi beam wend you instal second relay for hi.beam you connect the 12 volts (relay side) in the hi beam contact (+12v) and second wire(-) on the ground and you disconnect the hi beam and you pass second wire from batery (no,8 gage)(with fuse) and you connect that on the contact(primaire side) on new realy and second contact is for the lamp (hi beam ) and second contact on hi beam on the ground , the big power for hi beam d,nt pass by car realy the new relay have 4 contact 2 for winding 2 for load , wend you buy new relay he have diagram for connection in the box excuse my english ,,,
