Manual Gearbox seal sizes............
Yes...its supported just like that. The problem is...it depends on how proficient you are at removing theengine. If too many things are in the way, and you can't seem to clear the rear inside apron woth the engine components, you may find yourself removing those bolts. If so...don't let thetranny drop too far. If you put that long tail housing is a bind...you will crack it. The best thing to do...is remove the rear ring of sheet metal from the engine...including the plastic funnel, the oil filler cover the black square thing), the cap and wires..and leave the haner bar and muffler on it. Then you can extract the engine right back to the edge of the body sheet metal which lets the manshaft clear the clutch cover by about an inch...then carefully drop the engine. The tranny and all clutch hosing and shafts...stay in place. Ray
DeathBus
Post by DeathBus »
raygreenwood wrote:Yes...its supported just like that. The problem is...it depends on how proficient you are at removing theengine. If too many things are in the way, and you can't seem to clear the rear inside apron woth the engine components, you may find yourself removing those bolts. If so...don't let thetranny drop too far. If you put that long tail housing is a bind...you will crack it. The best thing to do...is remove the rear ring of sheet metal from the engine...including the plastic funnel, the oil filler cover the black square thing), the cap and wires..and leave the haner bar and muffler on it. Then you can extract the engine right back to the edge of the body sheet metal which lets the manshaft clear the clutch cover by about an inch...then carefully drop the engine. The tranny and all clutch hosing and shafts...stay in place. Ray
usually when i pull a bus engine i pull everything off the fan side of the engine. Shroad, heaterboxes, muffler, engine tin. I usually jack the bus way up in the air and use an el cheapo tranny jack from Harbor Freight to support the engine, then take the crossbar off. The wheels on the tranny jack make pulling the engine away from the tranny so easy, and you dont bend the studs!
vwbill
Dang Dang....
Post by vwbill »
Dang, Dang, so you are saying not to actually take the tranny mount bolts that go to the body out all the way.. So I could have gotten it out without taking them out! Dang! I swear I thought I tried not to but had to in the end....Crud! I hope i havent cracked a nose case somewhere but just have a overflow issue with it!
vwbill
pulling van motor?
Post by vwbill »
I always left the van on the ground and just pulled the bumper and front shroud and pulled it straight forward I thought? bill
DeathBus
Re: pulling van motor?
Post by DeathBus »
vwbill wrote:I always left the van on the ground and just pulled the bumper and front shroud and pulled it straight forward I thought? bill
Type 1 buses yes, Type 4 buses, no
vwbill
Post by vwbill »
Oh yeah, Damn what a reversal of a great design,lol! bill
DeathBus
Post by DeathBus »
vwbill wrote:Oh yeah, Damn what a reversal of a great design,lol! bill
I have a friend with a 69 Bus, I curse him every time he takes his rear apron off! :shock:
vwbill
Love that apron
Post by vwbill »
Yeah i loved that apron! I could pull my 1600 in probably 15-20mins! I had too a few times on the side of the highway,lol! bill
Also, bear in mind that the tailcone on the type 004 is not the same as the bus tranny and neither is the bushing and mount. Ray
