picks from road race bugs
Ozzie
Post by Ozzie »
H_Aich wrote:
ozzie wrote:Is the brake set-up available as a kit, or did you put that together yourself?
brake and clutch pedal.......Tilton
master cylinders AP-Racing and Girling
accelerator pedal is made by a friend
Sorry I wasn't clear. I meant at the wheels, not the floor.
The rotors & calipers.
I see Wilwood, did you have to mod the parts to fit or was it all just bolt together?
"When the people find that they can vote themselves money, that will herald the end of the republic."
Ben Franklin
Ephry73
Post by Ephry73 »
AMAZING! wow, another set of pants that need cleaning. The setup looks extremelly clean. What size engine and what tranny are you running? looks sequential as well. What the expected RPM range and how did you get the pedal assambly to fit propperly?
E
70dragbug
Post by 70dragbug »
Heinz sent me a mail and asked to translate some of the questions.
I like how you boxed in the bottom/front roll cage mounting points. That cage fits very tight. Can you show pics of how you tied your "motor plate" into the roll cage?
The adapterplate is bolted together at the top and bottom.On the topfrom the inside of the car there are rods welded to the wheelwells.The rods are connected to the adapterplate.
He created his own combination using the Wilwood calipers and discs.He also has different master cylinders to choose from and a variety of brake pads with different friction values,but he´s still in the progress of testing them.He can fully adjust the brake brake pressure to exactly how he wants it between front and back or just the pressure,the Scalebeam at the pedals is for fine tuning.
Motor is a 2666ccm type 4 max rpm 7200rpm, Hewland FT200 Tranny sequential shifting.The pedals are bolted to a self made adapterplate.(probably because the floor pans are pretty thin,that would give it stability).The gas pedal is fabricated by a friend.The other pedals are from tilton.
Cheers,
Mark
H_Aich
Post by H_Aich »
New pics !
bo
Post by bo »
did you raise the trans ?
Is your cage a "4 point" design? I can't see any tubing in the rear package tray area.
70dragbug
Post by 70dragbug »
The trans is moved forward a couple of inches to improve weight distribution.He races slalom races - for that he needs to have a lot of grip on the front wheels to be able to make quick turns and still remain stable.The car is set up with a short ratio gearbox - top speed is only about 100mph - but he can achieve that speed on a short course.
H_Aich
Post by H_Aich »
New Pics from our Project 2006
NEW PICS klick "weiter" to see the next Pic
H_Aich
Post by H_Aich »
Update Project 2006
racelook
Post by racelook »
Heigo isn't it?
Car looks great!!!
Wiebrand
Southernbug
Post by Southernbug »
The car looks terrific!
H_Aich
Post by H_Aich »
racelook wrote:Heigo isn't it?
Car looks great!!!
Wiebrand
It´s a Heigo
H_Aich
Post by H_Aich »
volksrod73
Post by volksrod73 »
That is one awesome looking beetle!!!
H_Aich
Post by H_Aich »
