CLKWRKS Upright Conversion
- dave t
Re: CLKWRKS Upright Conversion
Have you been to the Buggy builders show?
- CLKWRK
Yes many times as a vendor, lots of great stuff there
www.germanlook.net
1971 ghia build:
http://www.thesamba.com/vw/forum/viewto ... 44&start=0
Type 4 upright build:
viewtopic.php?f=1&t=134056
1971 ghia build:
- dave t
I was there again this year as a vendor.
- CLKWRK
we probably walked past each other a few times, I think we may have been the only group of Canadians there this year
www.germanlook.net
1971 ghia build:
1971 ghia build:
tonyorlo
What oil pump are you running? Where is your oil returning from the turbo at? I scanned through your thread but didn’t see any specifics on that stuff. Sorry for asking if you posted it.
- CLKWRK
i am using a schadek 26mm early t1 pump (8mm studs) with a plugged output hole, I also plug the case ... just like a T1
I have made a flange that bolts up to the oil filter boss that feeds oil back in where it would normally go. so there is a -10 oil hose that feeds oil there
www.germanlook.net
1971 ghia build:
1971 ghia build:
- CLKWRK
Hello everyone,
I have dumped most of the missing pictures from this build thread into a public album for everyone to be able to access them:
https://photos.app.goo.gl/fASzVUTGtgC1S9zx7
www.germanlook.net
1971 ghia build:
1971 ghia build:
- Wally
Is the 2,5ltr running yet?
H2OSB
BRYAN! Good to see you here! I mean recently.
H2OSB
H2OSB
I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants.
- CLKWRK
Heyo ... Yes I am still around, I have moved to Toronto now though
I built the 2.5L turbo T4 as an upgrade for the ghia along with a built 091 trans, but the ghia has been running flawlessly for the past 5 years so I haven't needed to do anything to it.
So I am building a whole other car around the 2.5 turbo (its a 912), so the 2.5 isn't running yet
Fun pics of that build here:
https://www.instagram.com/vantageaircooled/
here is one of my fav beauty shots of it from last season ....
Funny story about this pic, it was at a meet at the Porsche dealership, I was the only vw crashing it.
I have a a watercooling system to keep the turbo cool and I had overfilled it before the meet. You can see the puddle of glycol under my tailpipe ... I was embarrassed by that
www.germanlook.net
1971 ghia build:
1971 ghia build:
H2OSB
As I've told Lanner many times as I drooled over his 912, the 912 is a bucket list car for me. I doubt I'll ever have one...so I build Super Beetles.
I my opinion, you built the nicest Cali conversion I've ever seen. Is that what you'll do for the 912?
H2OSB
H2OSB
- Ephry73
I need a like button on here. Glad to see the old girl is still running well. One of these days I’ll get started on a swap. I’ll need a VW again first
- CLKWRK
I do have plans to put a cali conversion in the 912, I have already built most of it.
Now I am trying to figure out the clutch setup with the type 4 and the 915 transmission, Type 4 has a push throw out bearing and the 915 has a pull throw out bearing ... trying to convert pull to push
www.germanlook.net
1971 ghia build:
1971 ghia build:
Paging Wally.... Wally?
(he's traversed the 915 trans with t4 engine rabbithole so could advise)
From memory he cut the 914 flywheel to 228mm (nee 225) he had options as to push or pull pressure plates.
(don't recall which way it ended up. Bell housing needed shortened as well., )
Later went dual friction discs ~same plate.
Tried finding the appropriate threads... he was around 450hp and switched to the billet heads, but that was after the transmission upgrade.
- Wally
Well, ended up with the G50Piledriver wrote: ↑Mon Jan 15, 2024 8:17 pm Paging Wally.... Wally?
(don't recall which way it ended up….)
Good recall Pile!
With the 915 I did it the easy way: ordered the (Kennedy) 915 -> type 4 adapter flywheel, so you can you the stock (alu!) 915 pressure plate and 225mm disk.
With the 915 adapter flywheel the ring gear is on the pressure plate, the flywheel is therefore without starter ring!
