Damp, not dampen. Two different things, since you like definitions.KentT wrote: 4. One softer spring can dampen another stronger spring -- it is often done on the mechanical linkage for governors on small engines, for example, to provide smooth throttle control without surging/oscillation... It is NOT just "changing the base spring rate" that you seem to insist is the case.
Here's another one from a more reputable source than some random blokes badly worded Wiki entry, OED:
Still not happy? Have another:• technical a reduction in the amplitude of an oscillation as a result of energy being drained from the system to overcome frictional or other resistive forces.
Notice one thing in common? Both are through controlled energy removal. Exactly as per my earlier definition.a method of bringing about a reduction in oscillatory peaks in an electric current or voltage using an energy-absorbing or resistance circuit
I've seen a lot of twin sprung governors, and without exception they've all had the secondary spring for fine idle control (springs, outside a perfect world, are non-linear for small displacements at the start and end of their travel, hence the smaller spring used for control when the main spring is lightly loaded, it's for much more accurate control of the spring force)
I'd like to see this example of yours where it's used for damping, as I've never seen that, they've all been for the above reason, would you have a picture?
