Problem of the day. Post it up!
seabeebuggy
Re: Problem of the day. Post it up!
Post by seabeebuggy »
Yah sounds like fuel pressure to me
turbobaja
Post by turbobaja »
I bumped the boost up to 12psi yesterday and found both my Dell 40s leaking quite a bit of fuel from the throttle shafts. I'd seen a slight dribble from them @ 8psi, but it's much worse now @ 12. All the "sealed ball-bearings" are new, so it's either a poor seal on the O.D. of the bearings into the carb bodies, or the quality of the seals is on par with most other replacement parts these days :roll: . They both have machine-in inner shaft seals too, which all leak as well...replacements were NLA when I rebuilt the carbs recently...
I'm working on making my first cruise in this thing next weekend, with a 3,000ft. elevation gain & 125mi round trip. If the engine survives this "cruise", it deserves to be converted to EFI...
DON'T QUIT
CobraJet
Post by CobraJet »
Got Fire Extinguisher?
turbobaja
Post by turbobaja »
CobraJet wrote:Got Fire Extinguisher?
Yep! :mrgreen:
DON'T QUIT
MarioVelotta
Post by MarioVelotta »
turbobaja wrote:it deserves to be converted to EFI...
That's what i'm talkin about :lol:
The Dub Shop
Mario@thedubshop.net
1600 ITB NA - 18sec
Facebook-Tech-Store
shag55
Post by shag55 »
Just convert it you'v gone this far.
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
shag55.sl1racing@gmail.com
Facebook at SL 1 racing
Clonebug
Post by Clonebug »
My turbo puked,
It has serious sideplay and is leaking oil out of the turbine housing........time to install the spare turbo I found this spring.......
TerryTN
Post by TerryTN »
Wow, I just looked and I haven't posted since 2008! My problem? I got chunks in the valve cover :x Big chunks that aren't from the heads :oops: I pulled the sump cover and found more big chunks. Some are magnetic and some look like thumbnall sized pieces of the case. Ran good and had oil pressure when I parked it two weeks ago. My first guess is lifter and lifter bore.
Its been a good run. The case is over a decade old and has always had at least 120hp running through it in various configurations with the Engle W130? and 1.25 ratio rockers. I've been running Brad Penn oil and STP zddp additive since I rebuilt it the last time when I added the hide away turbo system. I'm beginning the teardown, so we'll see for sure soon enough.
miniman82
Post by miniman82 »
It *deserved* EFI from the jump, but it's owned by a procrastinator. 8)
turbobaja
Post by turbobaja »
Ha! Takes one to know one buddy :P . Get that alki injection and water/air cooler installed already!
...ok, you know I'll need you to hold my hand when I jump into the wonderful world of EFI.
DON'T QUIT
MarioVelotta
I think we all suffer from it in one way or another :)
The Dub Shop
1600 ITB NA - 18sec
Facebook-Tech-Store
Vee Dub Nut
Post by Vee Dub Nut »
^ mines not so much a procrastination issue, but an attention span issue. Before I'm even done with one project, I'm thinking about selling its parts to chase my newest idea LOL
Fightin' Texas Aggie Class of 2006
67 Beetle
74 Transporter (SOHC EJ25)
See all my VW pics on Instagram @ vee_dub_nut
miniman82
Post by miniman82 »
turbobaja wrote:Ha! Takes one to know one buddy :P . Get that alki injection and water/air cooler installed already!
I would, but my vintage color TV's need attention too. :P
Corysvdub
Post by Corysvdub »
I have a problem trying to adjust my fuel pressure to the desired 43.5 psi, I can adjust it to about 32# Max before it jumps passed the rest of the numbers and pegs at Max pressure. I changed the regulator because I thought it was that, but same problem.
Any suggestions?
Type 3 Subaru powered EJ25
56speedster
Post by 56speedster »
Do you have a pic of how you have the regulator plumbed and what regulator are you using? Is your return restricted somewhere?
The road to success is always under construction
