DEUTZ 912 CYLINDERS
sved
Re: DEUTZ 912 CYLINDERS
Looking good Don can't wait to here this thing purr!!!
- Type 4 Unleashed
No push rod to tube clearance issue ?
For me the springs get in the way when spinning push rods checking "0" lash , I just put a bead of Silicone around the end of the tube in the head, they never move.
EMW
EMW
- dstar5000
It was designed to move and on a bigger, wider engine this long, they need
to move about .040" at the head!
The Dirko goes on the ENGINE side to keep THAT side from moving. That is what
the springs are for, to keep it pushed into the engine case...
You say tomato, I say Mater, to each his own!
Don
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
of this presidency,".. Barack Obama January 21, 2009, 30 minutes before he signed the law
sealing all his personal information....
E_bug
Is there another Deutz engine type tha has the same bolt pattern witj tje type z4 but with smaller bore?
My welding sucks .
- dstar5000
100mm is the smallest.....
Don
Don
- benito26
perfect for 4" and massive boost
E_bug
I agree , i was trying to find ways to avoid cutting the spiggots on the case.
What thickness is required at the cylinder jug where it mates with the case.?
What would be an acceptable min thicknes.?
My welding sucks .
- dstar5000
109mm is STD to be used with 103 bore jugs.
Don
Don
ruffbiker
so... what happened to this project, does it run?
CaliforniaMilleGhia
did anyone get these to run......if not did anyone try and fail ????
Pictures would be great !
wreck
I've done one recently , 78x103 with 912 cylinders , the 912 cylinders are not a cheap option unless you have supplies of free used ones and able to do the machining or get it done cheap .
Mine has a scat C55 with 10.5 to comp and runs very cool . I'll have power figures late next month .
CaliforniaMilleGhia
a million years ago I had a set of 100mm P+Ls for a Type 4 ,
They were made in Japan , I think NPR
Not sure what you mean about the 912 cylinders since they are 82.5 mm I think.....
wreck
912 and 913 Deutz are 102 and 100mm standard bore .
CaliforniaMilleGhia
ahh I was thinking 912 Porsche.....
- petew
Will these only fit in a type 4 case or could you also fit them into a type 1 case?
