**Night Run prep**
Re: **Mojave Road prep**
Skidmark wrote: Mon Jul 22, 2019 10:39 am When you have some spare time, practice with your MIG welder some more. Just sayin'... :lol: :lol: :lol: You may want to be careful side loading that extension. You did not get very much penetration to the floor jack cup from the looks of that.
Yes I need to add a fifth bead on there to cover that edge up. I’m confident in its holding ability as is though.
Skidmark
Post by Skidmark »
Okay, the 4th bead looks cold at the jack plate. 😉
Skid it is my job to give you guys something to get me on. I fly that flag proudly as you can coldly see. 😂😂😂
Skidmark
Post by Skidmark »
I certified aerospace welders as part of my job. Gotta speak up when I see something that looks off. Any time the weld bead edge is 90 degrees to the parent material, there is a lack of penetration. Another tip is to make sure both pieces you are joining are ground to shiny metal prior to welding, and as clean as possible. Not that you didn't, just another tip. I see a bunch of welds online that people think they can burn through contamination. You can never make the metal too clean to weld!
Skidmark wrote: Tue Jul 23, 2019 10:37 pm I certified aerospace welders as part of my job. Gotta speak up when I see something that looks off. Any time the weld bead edge is 90 degrees to the parent material, there is a lack of penetration. Another tip is to make sure both pieces you are joining are ground to shiny metal prior to welding, and as clean as possible. Not that you didn't, just another tip. I see a bunch of welds online that people think they can burn through contamination. You can never make the metal too clean to weld!
Skid, do you also certify to weld upside down (on your back or bent over backwards :wink: ). When I was trying to get on the old Boeing Hydroplane design (military then commercial) and build I had to get into welding design processes, specs and certifications for welders. WOW, was it tough.
One of the guys I knew at the time, a good welder, could only pass one of the methods and positions of welding (I don't think hanging by your feet was one of them but it was close to a couple of them) and only one of the materials that would need to be welded. Welding is an art form per se on many levels and that is for sure.
Skidmark
Post by Skidmark »
Lee, those are some of the hardest positions to weld without a doubt. Luckily, our government contracts did not require welding inverted or vertical. We did welding on Patriot missile parts, and other parts for Raytheon. We also did a temporary exhaust cone and heat shield for the Northrop Grumman X-47B, the unmanned fighter. We were involved in a lot of really cool projects over the years!
Skidmark
Post by Skidmark »
Some of the MIG welding we did. I will have to hunt up some more pics - buried on one of my hard drives.
Purdy! I really appreciate good work especially when it looks like good work.
Re: **Night Run prep**
Have all my brake parts and reworking this mess out. Should have a extra axle setup when done.
CentralWAbaja
Post by CentralWAbaja »
That is one hell of a mess.....You have an empty beer coozie!!!
CentralWAbaja wrote: Thu Aug 01, 2019 7:18 am That is one hell of a mess.....You have an empty beer coozie!!!
It wasn’t empty, had my balls in them. 😳
I hate messing with CV’s
Did I mention I hate working, greasing CV’s? Well they are done, both side with new axles, greased and clocked. Also put the new main springs on, went 2.5.16.350, only went up 50lbs each side. Will see how it rises.
Was having just so much fun on bleeding the brakes, I think I got it. viewtopic.php?t=151347
Skidmark
Post by Skidmark »
Great work, Leather!
