Downunder turbo oval & Datsun 510 adventures
petew
Re: SOLD - 1600 TURBO + oval + downunder
Post by petew »
Alright. So it's taken me long enough, but look what came in the mail yesterday...
This is a big deal. I've been wanting to go turbo ever since I bought the car, but it's only just now that I do so. This is also in the mail.
https://www.ebay.com.au/itm/200745049655
AU$175 for this bad boy Chinabay turbo. Just need oil and exhaust hookups. Everything else in the car is ready for it. Fuel. MS2. Trans and diff. I do want to work out some sort of intercooler. It'll be blowing into a pretty tired engine, but I've got another one in the wings.
Good to have you back|, those 510s go for goo $$$ over here as well...
I wonder if a vr38dett would fit >;-)
I don't recall if you can stack maps in MS2e. Want to say yes...
woodsbuggy1
Post by woodsbuggy1 »
Hello Pete,
Great to see you are making progress! Please keep sharing your build.
Kenric
petew
Post by petew »
Piledriver wrote: Fri Apr 11, 2025 8:51 am Good to have you back|, those 510s go for goo $$$ over here as well...
There are a few people who've put VG30s in, but not with turbos. Sadly, we live in a Nanny state here. I talked to one guy who fitted a VG20DET. Yep, a 2.0l turbo v6 to his 510. Feels like a lot of work for a 2.0l turbo, but he says it's a great cruiser.
petew
Post by petew »
woodsbuggy1 wrote: Fri Apr 11, 2025 5:18 pm Hello Pete,
Kenric
Sent you an email! :)
petew
Re: Downunder turbo oval & Datsun 510 adventures
Post by petew »
Been having issues connecting my new laptop to my bluetooth adapter. It's a windows 11 issue and here's the fix.
https://geekrewind.com/how-to-turn-on-o ... ws-11/amp/
petew
Post by petew »
Okay, need some tunerstudio nerds... Got my car doing this weird hunt where it almost dies after firing up.
It's not closed-loop. It's just set on warmup then the idle motor turns off.
Chip Birks
Post by Chip Birks »
petew wrote: Mon May 05, 2025 4:07 am Okay, need some tunerstudio nerds... Got my car doing this weird hunt where it almost dies after firing up.
Are you controlling timing? Or is this a fuel only install?
petew
Post by petew »
Chip Birks wrote: Mon May 05, 2025 7:15 am
Yes. Crank trigger and wasted spark with a Microsquirt.
Chip Birks
petew wrote: Mon May 05, 2025 5:23 pm
I couldn't see ignition timing on the data log. What is it doing in that zone?
petew
Post by petew »
Here's the ign map.
I've redone the datalog too...
Alexander_Monday
Post by Alexander_Monday »
I use MAF so not sure if this translates, but I found that adding timing below idle helped to stabilize it.
If you are using PID closed loop idle, I'd guess that your closed loop sensitivity and or proportional gain is a little too high or derivative gain is a little low.
Also, if you are using stepper idle control I found that making a restriction in the line to the stepper valve helped on mine so each step gave a smaller change in idle air flow.
I did go too small at first and had to open the restriction up to find the sweet spot on mine.
YMMV, just my trial-and-error experience so take it for what you paid for it.
petew
Post by petew »
Hmmm, interesting.
I'm only using the stepper idle control for warmup. After that, it's just TB position. I live 7km up a hill. Most of my warmups are long and the ECU didn't seem to cope with that. It did odd things with the idle control because it expected the car to warm up faster. So yeah, I had to turn off the closed loop. Which is irritating, because it worked very well on the ACVW setup. When you say restriction, how much are you talking about?
Alexander_Monday
Honestly I do not remember.
Mine is not normal, I modified the Diyautotune custom idle air control body and my 65mm Ford 5L throttle body and cut a gasket and incorporated it directly to the throttle body where the original solenoid style was.
I put a 3/8 NPT plastic allen set screw in one of the holes the barbed fittings goes into and drilled a hole in it.
Then I drilled it bigger until the step size worked good.
