1641 Turbo EFI Manx. 250Hp/337Nm Turbotub
rubenski
Re: 1641 Turbo EFI Manx. Stage 7: engine rebuild
Post by rubenski »
Where we´re at with ne new injectors. 15psi
Came from this, the 2 bottom lines red and blue are the old ones
Verstuurd vanaf mijn SM-A528B met Tapatalk
rubenski
Post by rubenski »
https://fb.watch/loElaJcwxB/
That´s where we ended. Verry happy with the gains with only bigger injectors.
My guy is going to continue tuning it today and tommorow. Buggy is still at his shop.
Had some problems achieving higher boost levels. To be continued
panel
Post by panel »
Great HP #'s for that displacement , WOW !!!
rubenski
Post by rubenski »
Thanks Panel
my_medusa
Post by my_medusa »
do you datalogg this time? i don't belive that this turbo can hold 21psi over the whole rpm range on a 1641cc. if you have allready 234hp @15psi then this is close to the max boost. results plus rebuild is nice and sweet. whats the hot side of that turbo? a 6cm2?
rubenski
Post by rubenski »
Not datalogging yet, first searching whey it wont boost further than 15psi. We did manage to see 21psi two times but the ecu threw us out at 4800rpm.
My tuner is searching in the ecu for where problems come from.
He´ll figure it out.
Seeing that clonebug is pushing 21psi for a few years on the same turbo...
my_medusa
Post by my_medusa »
what ecu are you running and why no datalogging? do not understand where the tuner is seachching if not first in the loggs?
that turbo can see way more boost than 21psi. i just said i do not belive that it will hold that boost till your "redline". you will find out if or if not. and dataloggs will help.
rubenski
Post by rubenski »
Running the cb gen4 efi.
Main goal saturday was to get the new injectors tuned
He tunes in realtime adjusting the fuel table values.
When I have more new´s, i´ll post it here!
my_medusa
Post by my_medusa »
had a quick look at clonebugs build first page. he has a stock 1584cc if not changed later and his turbo has a 9 blade turbine wheel in it that is definitly not a stock wheel i bet yours have 12 blades. at 5500rpm your torque is allready falling thats why i would not tune the hell out of it to reach that 21ps goal, it may physically not possible. you can overrun that tiny turbo infact of the small exducer compressor wheel but if the hot side chokes it chokes. 57cc and that 9blade makes a big difference. but at the end doesn't matter good luck to get the moste out of it how it is. 👍
rubenski
Post by rubenski »
What could be a sign that we´re spinning it to fast?
rubenski
Post by rubenski »
Seems like my guy fixed the issues
rubenski
Post by rubenski »
Problem was an overboost setting problem that wasnt in psi like we tought but in kph/kpa. Cb gen4 efi is confusing sometimes.
My guy ended here:
Can´t say how happy I am.
Picking it up tommorow.
He´s only gonna clean up the lower section of the fuel table for driveability.
I´m not at his place now but he say´s the engine is craaaazzzzyyyyy
rubenski
Re: 1641 Turbo EFI Manx. 250Hp/337Nm Turbotub
Post by rubenski »
The final result, could´nt be more happy.
panel
Post by panel »
Gunna be a handfull !!
xzener
Post by xzener »
Wow! 252hp, thats amazing. Congrats!
Boost is contagious.
