Interesting unit. Back a couple of hundred years ago when you "dropped the hammer" at high RPMs, the clutch engagement was an immediate shock load. "Deck shifting" then come in and it was for the same/similar reason... no reengagement of the clutch once contact was initially made. A lot of trans and other parts could be quickly dam(n)aged.
On my lightened flywheel (I forget how light it is (now [15# I think]) but it is light and RPMs quickly and is combined with a 4-puck clutch disk. With my setup, "Slipping the clutch" can destroy a flywheel face very quickly. The sand dunes where I ride the loading on the drive system is pretty constantly under load/drag.
Haven't been on the drag strip or even talked to anyone who now does for probably pretty close to 40 years now.
