Problem of the day. Post it up!
madmike
Re: Problem of the day. Post it up!
Hey Heinz, maybe an electric pump is in order? holly red or Blue is what I'm using and a boost ref holly regulator
Heinz Willie
Thanks for the response MadMike I can totally do that, but sometimes it's the challenge of just figuring it out. Others have done it with mechanical pumps, so I'm wondering if I have a known problem here that people live with or maybe I'm the only guy with a center mount blow through and a mechanical pump combo? Or possibly I've got another issue I have yet to figure out ....madmike wrote:Hey Heinz, maybe an electric pump is in order? holly red or Blue is what I'm using and a boost ref holly regulator
madmike
Ya once I switched to 48 Ida's I needed the flow so Holly Blue did it, I've run stock pumps with 44 IDF's with no issues.when They were N/A
since my cars are set up for electric pumps I'll use them for Turbo
- Fiatdude
I'd like to recommend using a by-pass regulator on any Holley pump -- I was always having a short life span on my pumps and once I went to a by-pass reg with a return line my pump temps went way down and their life span went way up
madmike
I'm switching to a red pump, I think the blue was to much for the 2276 and it was flooding the carb so bad I have fuel dripping out the Aux vents @ idle
also 'cracked cylinders' on the last pass
but I' so deaf couldn't hear detonation if my ass depended on it
plus the fact I had the boost cranked up as high as the little control knob will go
madmike
Hey Harold,I grabbed a Bypass reg. Areomotive from Jegs on my last order
seems my helper read the fuel pressure Gauge
WRONG
was set too high
on the last setup,,,
WRONG
andy198712
Don't blame someone else
madmike
,,,HaHa u must know my wife
But it's my Pit chiefs' fault
I can'nt see/read the gauge from the cockpit,it's mounted on the carb
madmike
who stocks a rebuild kit/diaphragm for CarCraft/Turbonetics WasteGates??????????????????????
I need two
I need two
- MarioVelotta
Turbosmart
The Dub Shop
Mario@thedubshop.net
1600 ITB NA - 18sec
Facebook-Tech-Store
1600 ITB NA - 18sec
Facebook-Tech-Store
madmike
Hey Mario,, as in a new Turbosmart gate?
or do they have parts? got a link?
Thanks,Madmike
Thanks,Madmike
- Chip Birks
New gate
- MarioVelotta
I was referring to a new Wastegate, should have been a little more specific.
The Dub Shop
1600 ITB NA - 18sec
Facebook-Tech-Store
1600 ITB NA - 18sec
Facebook-Tech-Store
madmike
but these are so 'purdy'
and I was hoping to use them
- Chip Birks
So dang big though
