AMR500 on a 1600cc - V2
grelland
Re: AMR500 on a 1600cc V2
Post by grelland »
Wow, I see I have not updated this in a good while, so I guess it is time :)
Last post was in August, and even though more or less the entire show season was cancelled last year, we managed to get together a fantastic trip around the Norwegian fjords and mountains, so after some conciderations, I decided to t1ke the SC off for this trip. We are talking some 750 miles up and down Norwegian mountains and fjords over 3 days, and the weather forecast said 25-30 °C so I concluded that the heat issues could potentially destroy this wonderful experience.
So here are a couple of pics from the trip :)
As you can imagine; a fantastic experience :)
During the long light nights on that trip, I have a chance to talk to a lot of great Norwegian fellow VW-nuts, so when I came home, I decided to finish up my 2110cc oxyboxer, so that I could have some fun before winter came, so I focused on that engine for a couple of weeks, and finally managed to install it in the car:
Interesting color choice, but since I always try to involve my boys in the builds, they were in charge of the paint, and that is the result :)
grelland
Re: AMR500 planning on a 1300cc - turning into a build thread
Post by grelland »
The oxy worked great, and it pulls quite hard :)
https://youtu.be/Ib-BZKQ5Gnc
But winter came and the car was put in storage, so that we could start planning and working on the supercharged 1600 v2 :)
The main challenge from my side was the heat management, and I soon concluded that I wanted to add some sort of charge cooling. After some thinking and again discussions with fellow VW-nuts, I wanted to look at a solution using a water-to-air intercooler. More on that later.
First I opened the engine and inspected all the oily bits. I had no idea how many miles it had run, so when I decided to supercharge it last spring, I was well aware that there was a certain risk linked to that.
grelland
Post by grelland »
In general, the internals measured out ok. End float was within tolerence, and the only thing I ended up doing was a line bore to bring everything back to spec.
I also opened the case up for full-flow and performed the "hoover mod" while I was at it.
Most of this is standard stuff for most of you, so I will not spend too much time on sharing pictures of this.
When it came to the heads, they looked good (no cracks) so I cleaned them thoroughly, and my son got his CNC-mill up and running so he machined them down a tad so that I ended up at 8.5:1 in static CR.
I also had to replace a couple of the exhaust valve guides, as they were way outside the tolerence.
Then I did a mild porting job, as I have no clue what I am doing, so I limited myself to match-porting to the CB end pieces, and cleand up the exhaust ports a little. I also made a couple of brass inserts to ensure the end pieces and heads matches up every time:
So aside from the regular problems with cam bolts fouling the oil pump etc, I finally could conclude that I now have a decent longblock:
grelland
Post by grelland »
So the spec on the engine itself is as follows:
Stock 69mm crank and rods
Stock pistons and barrels (new rings)
All new bearings
JB200 cam (from JoeBlow in Australia)
mildly ported stock heads
scat 1:1.25 rockers
chromoly pushrods
This means that my redline will still be in the 5300 rpm range, so max drive ration to the SC will be about 3:1 (as I used last summer)
grelland
Post by grelland »
So back to the intercooler.
I toyed with the idea of adding an air-air intercooler, but concluded that even though thay may have worked ok, I think that even though I have quite a lot of space in my engine compartment, the IC would heat up the intake air that is being used for cooling the engine, so that would not be optimal. Alternatively i would have to make a separate air intake that led cold air directly to the intake of the fan. That could be done from underneath the car, but i decided that that would become too much work, so I landed on a water-air solution in stead.
So after some search and head-scratching I landed on an intercooler from siliconeintakes.com, that is rated up to 350 hp, and with a pressure loss at 0.1 psi.
It looks like this:
http://www.siliconeintakes.com/front-mo ... p-210.html
So before I pulled the trigger, I made a rude 3D-model an 3d-printed a mock-up in order to check the available space in the engine bay:
Even though I have my dry sump oil tank inside the fender, I still have some space left.
So a quick mock-up on the engine stand revealed that this could certainly be a viable solution:
So the credicard took a small hit, and I could start preparing the rest of the auxillaries.
The next generation is still head of the paint department so the SC got a shower:
But I wanted a bit more toned down look overall, so the rest of the tins and hw received some satin black powder coats:
grelland
Post by grelland »
After some debating on what fan shroud works the best, I ended up deciding to use a late model doghouse model where I have removed the outlets for the heater. I think the 36-hp ones look better, but since heat management is/will be an issue, I dont want to cut corners there.
So the oil system will be a quite standard one, with stock cooler in the doghouse, and a full flow system with an external filter and additional cooler under the car.
Then we are almost up to speed on the project, as I spent the weekend fabricating alu intakes and flanges, so the following images shows where the project is today:
My son made the flange on his cnc-mill
So the next on the list now is to weld the flange to the intake pipe, and then add some bungs for some sensors.
I intend to add two IAT-sensors; before and after the IC, in order to see the cooling effect.
I also need to source the rest of the water system: radiator, pump and an expansion tank, so any hints as to good sources for this will be highly appreciated.
Stay tuned for more :)
buguy
Post by buguy »
I got my radiator and fan at silicone intakes. http://www.siliconeintakes.com/
For the pump i got a "Rule" 1200 gpm pump. It's a Marine bilge pump. I think i got that on Amazon.
Made my own tank out of aluminum sheet. I just used a 5" boat deck plate for a screw off lid. Big enough you can get your hand in to it to mount the pump and to accept ice when needed!
grelland
Post by grelland »
buguy wrote: Mon Feb 08, 2021 10:21 am I got my radiator and fan at silicone intakes. http://www.siliconeintakes.com/
Thanks, I will have a lokk. What size radiator did you end up with?
grelland
Post by grelland »
Short update from yesterday's activity.
My oldest son moved out this christmas and took with him a lot of his machines, but he only lives 5 minutes from my house, so he drops in every now and then. So yesterday when he stopped by, I had him weld the flange on the intake tube:
I am still not a friend with the TIG, and I know that the only thing that helps is practice, but is is so much more conveniant when he just does it ;)
We also decided to have a look at the other short intake tube; the one between the TB and the SC, and from last year, I know there is some optomising to do. One of the issues was that the tube is 48mm, but the flange on the TB is some 60mm i diameter, so we set the tube up in the lathe (that machine is mine, so it remains in my garage ;) ) and made a nice taper out to the 60mm opening. I will face off the flange also to ensure a good seal to the TB:
Next on the list is to make some brackets to hold the IC in place, and then I will powder coat all the bits and pieces.
Great fun, and still snow on the ground here in Norway, so no immediate rush to finish.
grelland
Post by grelland »
Only thing I got done today was to face off the flange so that it will hopefully seal well against the TB
chickensoup
Post by chickensoup »
This thread incorporates lathe tools and fabrications!?!? I'm in!
btw just curious but what lathe?
buguy
Post by buguy »
Right. I love that stuff even though i don't know how to do any of it!
grelland
Post by grelland »
chickensoup wrote: Tue Feb 09, 2021 12:00 pm This thread incorporates lathe tools and fabrications!?!? I'm in!
Thanks for the kind words ;)
a small chinese one ;)
buguy
Post by buguy »
We have a big one at work. I was going to use it one weekend but i couldn't figure out how to turn it on. Figured that was a sign that maybe i shouldn't be messing with it!
Chip Birks
Post by Chip Birks »
buguy wrote: Tue Feb 09, 2021 2:38 pm We have a big one at work. I was going to use it one weekend but i couldn't figure out how to turn it on. Figured that was a sign that maybe i shouldn't be messing with it!
Lol, good thinking. Watch a couple lathe oops videos and you'll be unconverted real quick. Definitely not a machine to mess with if you don't know what you are doing.
