Whoof! Just for clarification before I posted anything, I looked up the term "AN10" and got several answers also 10ANs (something different). One version got coverage started in something like 1959 but I think the AN series I am use to is much older than that (not 100% on that either). Anyway, what they are describing is a lot of different things including bent tube (like gas and oil tubes), different types of fasteners and things like Airplanes.split1950 wrote: ↑Tue Aug 22, 2023 12:01 pm Also, whilst I'm "in there" is my turbo oil drain to Tuna can OK?
I used AN10 PTFE. It goes downhill to the Tuna can.
But, isn't the Tuna can the lowest point of the oil pan even despite dry sump it won't be empty?
Would a 3/8 NPT banjo to AN10 survive on the centre housing (heat?)? That way I could tap into the side of the sump.
I'd like to hear from people using the Tuna can rather than an opinion if possible
If you are using the slang term "AN10" for a 90-degree fitting (the cast version of the MIL-spec [there is more coding involved other than just the "AN10" name) which I think, along with the pretty braided fuel line was designed back in the early days of jet engines and I think maybe in bombers during WW2. Hotrodders got involved with the term (and use) during the Korean war (if I remember correctly). I got into the terms in the mid-60s then into the detail of the MIL specs in the mid-60s.
If you are using short lengths of the braided fuel line you should be OK for show, not so for long line (say the length of the pan up to the engine because it, like the rubber tube fuel line (both can age quickly and start to sag between clamps allowing the potential of gas air to collect there) but not so well for the longer run. The rubber can fail also over time.
The fitting would have more coding to it but if the "AN10" (et al) follows the specs I had to deal with the 10 stands for 5/8" line (coded in 16ths of an inch or 20 in 32ths of an inch MIL specs).
I hope this is somewhat clear.
