AMR500 on a 1600cc - V2
buguy
Re: AMR500 on a 1600cc - V2
Post by buguy »
I think my radiator is a bit smaller than that and seems to work ok. I'm sure bigger is better in this case but it may be worth a shot since you already have it. I also made a scoop. I think my tank with long 3/4" lines holds 3.25 gallons. Don't remember for sure 100% though.
panel
Post by panel »
Rad looks good re dimensions .
grelland
Post by grelland »
Thanks for the replies, guys. I think I will use this as I already have it, and I have mounted IAT bungs both before and after the IC so I can monitor the effect. Maybe I also should add a couple of temp sensors on the water-side. I honestly dont know how many spare inputs I have on the microsqirt, so I guess I have to do some reading first ;)
panel
Post by panel »
You can also add a fan to that cooler if it gets above the temp that you're looking at. Either through the MS or a manual one or some inline temp switch at a set temp etc.
sebug23
Post by sebug23 »
Hi, do you guys know if my mexican fuel injected would work with the amr500 with the stock ecu and distribuitor?
Bruce.m
Post by Bruce.m »
The stock ecu is unlikely to add the needed extra fuel once boost has raised the intake manifold pressure above atmospheric.
chickensoup
Post by chickensoup »
I remember the when I was trying to use the german type 1 efi in a 1776 the injectors were about maxed out. I think with a new ecu like speeduino or MS and larger injectors and bigger fuel pump you'd be good to go.
