As said before I am fitting a CB 82mm crank with CB H beam rods.
I actually found that carefully using a belt sander was the quickest way of removing material, maybe my die grinder is dying.
nsracing wrote:You are NOt going to run the grinder all day long. You just need short bursts of spins. 30 second spins and check the cut....spins some more and check the cut.Buggsy wrote:Don't buy bits and a die grinder unless you have access to a professional size air compressor. The thirty gallon, one lungers that most of us use to run impact wrenches will burn up before you get the job done. Die grinders consume a huge amount of air.
I do not know anyone that runs the rotary file continously.![]()
Here are more pics..
cam clearance..
