That's what I have.Buggsy wrote:Get a carb with vacuum operated secondaries. It will open them if it needs the flow.
I used a vac. sec. spring kit from Holley to tune it's opening point.
It's been running great since I tuned it in the Spring.
FITNESSFORYOUTOO wrote:Hell I have a new stock complete engine lying around and I am going to build one of these just to see what it will really do in a 1500 lb race car
If you're not going to use some timing control like the MSD, watch your compression!VdubsNWPA wrote:I appreciate all the info you guys have provided.
I'm going to turbo my rail... it is probably right around 1000 pounds, and i'm going for as little cost as possible.
MO, my goal is to get as close to your setup as I can, minus the MSD stuff for now.
My friend has a pile of old carbs laying around, as soon as i get the time to go over there, i'll look for the holleys with small bores and start writing down numbers. i'll post the numbers and hopefully you can help me pick the one that will work the best. I'm sure it will need rebuilt and jetted and my dad knows a guy that's been tuning holleys for 20+ years so i can probably have him rebuild it for me with the jetting setup that I choose.
I'm still looking for a T25 turbo, but a t3 would be easier to find... how much would the boost response differ between a t25 and a t3? I want to be able to spool asap for more bottom end torque. that's where I want my power.
